Dumb question but it must be asked
Old May 7, 2009 | 10:26 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Ok i know this is the dumbest question off all dumb questions for gauges but how on gods beautiful green earth do you pull out the gauges or gauge cluster for the speedo and the rest of the gauges? this is driving me crazy i;ve tryed numorous times and i couldnt figure it out. Im trying to swap out my oil pressure gauge, temp gauge and redo my whole speedo cable and possibly redo the entire setup in the near future. Thanks for any and all help
Old May 7, 2009 | 11:10 PM
f-body animal's Avatar
Car: 85 IROC-z , 88 GTA
Engine: IROC 305tpi, GTA 350tpi
Transmission: 700r 700r4
Axle/Gears: IROC 308 10bolt gm/GTA 327 9bolt
Re: Dumb question but it must be asked
once you remove all screws the speedo should have a clip behind it use a long flat screwdriver to push clip foward speedo cable should slide out. as far as gauges go they should interchange except the tach/oil gauge are diff. on 6cyl oil gauge reads 80lbs v8 reads 60lbs.the tachs are diff.
Old May 8, 2009 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Black Z28
how on gods beautiful green earth do you pull out the gauges or gauge cluster for the speedo and the rest of the gauges? Im trying to swap out my oil pressure gauge, temp gauge and redo my whole speedo cable and possibly redo the entire setup in the near future.
Check the following link for cluster removal (and trip odometer repair):
https://www.thirdgen.org/forums/faq-...-fix-pics.html
BTW, you can access the gauges from the front of the cluster without cluster removal. Remove the plastic bezel, the metal bezel, and the lens. The gauges are held in place with a screw of two. Remove them and simply pull the gauge in question toward you.
JamesC
Old May 8, 2009 | 10:08 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
coool, thanks guys. yea my 145 speedo hasnt been working for awhile and its pissing me off. thanks guys
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
89gtaforsale
Aug 24, 2015 09:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
