Loose shift knob? Come in here...
Old May 15, 2009 | 11:48 AM
jimmyj2000's Avatar
Car: 88 Formula 350
Engine: l98
Axle/Gears: 3.23 9-Bolt
Loose shift ****? Come in here...
I'm not sure if this would work for Camaros, but while I was replacing my console, I figured I would share how I fixed the wobbly shift **** on my Formula. It's pretty simple, all I did was remove the shift ****, and carefully squeeze the two clips a little bit with some vise-grips, and it feels like new again
Old May 16, 2009 | 11:55 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Loose shift ****? Come in here...
What do you mean by "loose"? Did your wobble around?
Old May 16, 2009 | 01:44 PM
jimmyj2000's Avatar
Car: 88 Formula 350
Engine: l98
Yes, it was wobbly.
Old May 16, 2009 | 05:38 PM
HCR13's Avatar
Car: 1987 Trans Am
I never had that problem. Was the c-clip inserted?
Old May 16, 2009 | 09:24 PM
jimmyj2000's Avatar
Car: 88 Formula 350
Engine: l98
Yes, the clip was inserted. It is just that somehow over the years, the notch in the shifter rod either wore down a little bit or separated a little bit. I just thought I would just throw this up here in case anyone else had similar issues.
Old May 16, 2009 | 09:37 PM
HCR13's Avatar
Car: 1987 Trans Am
I see, thanks for the info. I wasn't aware the auto shifters could loosen up...
Night rider327
Feb 25, 2016 09:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
