pull down motor test
Old Jun 3, 2009 | 08:05 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Ok my camaro has an electric hatch, but its not hooked up. by that i mean there is no switch in the car for it and the wires are all unplugged at the hatch its-self. If i want to open the hatch i just go back and use my key. My question is how can i test the electric unit to see if it will pop the hatch to work correctly. Im not even sure what its supposta do as ive never actually seen one work. Any help guys, ive been searching for about an hr.
Old Jun 4, 2009 | 09:36 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: pull down motor test
Not all of cars with the electric motors allow remote "pop" of the hatch; most of the time its just there to close the hatch. If you do not have a switch inside the car, chances are you do not have the correct parts currently to allow remote release. Adding this feature, that's another story.
Old Jun 4, 2009 | 11:18 AM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
There will be an extra solenoid mounted to the motor. It should have a single wire connection. If there is no solenoid, then you dont have remote release.
BRoss99
Aug 10, 2025 05:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
