Steering Wheels
Old Jun 8, 2009 | 06:01 PM
nemoose5's Avatar
Car: 1991 RS
Steering Wheels
I can't stand my 91 airbag steering wheel any longer, its all fraying and chipping apart. I am looking at purchasing a new one, but not sure how they would look inside my car. Ive seen a lot of Grant wheels. Just looking for opinions
Old Jun 8, 2009 | 06:56 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
Re: Steering Wheels
There are a lot of really good looking Grant steering wheels. I think you are going to run into the same problem I have. You will probably have to trim the steering column cover to fit the new wheel. Grrant does not make an installation kit for the air bag wheels.
Old Jun 8, 2009 | 07:32 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Steering Wheels
i just installed a grant in mine , ditto on the airbag . retain the yellow spool/spacer and re-use as a spacer . it can be done but you will have to improvise some . you will have to trim about 1/4" from column plastic . good luck .
Old Jun 10, 2009 | 10:13 PM
reedo282's Avatar
Car: '92 Z28
Re: Steering Wheels
Yeah, I was wondering the same thing.
I have a '92 Camaro Z28 and have a steering wheel with an airbag and I want to put in a steering wheel from a Firebird. Will this one bolt on to my car? I don't care if it has the Firebird logo on it.
Old Jun 11, 2009 | 03:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Steering Wheels
A 4th gen wheel is a direct bolt on, with the exception of the airbag electrical connector - just attach connector from your old wheel. Trick is to find one at a boneyard in good condition with airbag still in tact.
Old Jun 12, 2009 | 10:50 PM
reedo282's Avatar
Car: '92 Z28
Re: Steering Wheels
That's a third gen steering wheel....and it has no air bag....
Old Oct 4, 2022 | 04:36 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Re: Steering Wheels
I never installed a steering wheel before, any special tools needed? 1987 Iroc-z.
Old Oct 4, 2022 | 04:39 PM
Car: 1987 Iroc-z
Re: Steering Wheels
I never installed a steering wheel before, any special tools needed? 1987 Iroc-z. I am intersted in the screaming chicken steering wheel, sounds like they have it all figured out. (no column rub and easy horn connection).
Also, who makes that wheel? manufacturer?
Old Oct 6, 2022 | 11:34 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Steering Wheels
You'll need a steering wheel puller kit -- most auto parts stores will just rent you one. Costs nothing, as long as you bring it back complete, and not damaged.
Old Oct 6, 2022 | 02:46 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Steering Wheels
Just recently replaced my original 91 Firebird steering wheel with a wheel from a 84 Trans Am that I refurbished, paid $20-30 I think
El Diablo
Aftermarket Product Review
27
Jun 21, 2020 10:15 AM
atgrissom21
Nov 5, 2007 04:55 PM
hawkwilliam
Feb 15, 2006 04:52 PM
WaFFLesZ28
Jul 2, 2005 06:07 AM
bac67
May 31, 2004 09:33 PM
