Sticky carpet patches
Old Jun 24, 2009 | 01:17 AM
Jekt's Avatar
Car: 1983 camaro
Engine: 350 soon to be 355
well i did a search in this board and didnt really find an answer. i pulle dup my carpet(tossed it sooo nasty) and need to get the sticky swatches/patches up to i can rust bullet the floor. I have seen suggestions like acetone, gasoline and push it into the sun(lol).
just wondering if there is something easy to use. i tried acetone but maybe i just didnt use enough? i really dont wanna spend 3 days scraping at these patches only to give up.
Old Jun 24, 2009 | 07:25 AM
DJReynolds's Avatar
Re: Sticky carpet patches
Wire wheel on a grill.
Old Jun 24, 2009 | 05:57 PM
Jekt's Avatar
Car: 1983 camaro
assuming you mean drill, and i have tried that didnt seem to work. just seemed to push it around not really remove it. I can always try it again maybe i just didnt hold it in a spot long enough.
Old Jun 24, 2009 | 10:55 PM
Net-Viper X's Avatar
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
Are you talking about the places where the carpet insulation was glued to the floorboard in a few areas? If so get a heat gun and warm it up real good to soften the adhesive then use a razor blade scraper like you use to scrape old decals off glass and start at a corner and start scraping it off. Just be careful and dont get in a hurry and slice your fingers.
Old Jun 24, 2009 | 11:26 PM
dstss's Avatar
Car: 1992 TA Convertible
Engine: 5.0 TPI
Transmission: THM 700
Try Goo Gone or something similar. I removed vinyl flooring from my trailer floor which left glue all over. Goo Gone was the only thing I found (after trying everything else in my garage) that got it off. You can get it at autoparts stores or Home Depot.
Old Jun 25, 2009 | 12:08 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
The sticky patches on the floor are there to seal around the plugs in the floor.
They are very easy to remove with a heat gun (or a torch) and a chisel. Don't use a wire brush on a drill, that just throws stuff all over the inside of your car.
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
italiano67
Sep 22, 2015 08:42 AM
Numbah-1
Sep 20, 2015 09:31 AM
bubbaz28
Sep 18, 2015 02:09 PM
