Auto shift knob removal...?
Car: Had 2 iroc-z's . An '87 & '88.
Engine: HAD 5.0 & 5.7 tpi
Axle/Gears: stock
Auto shift **** removal...?
Hey guys, on a '85 iroc how do you remove the automatic shifter ****? I want to replace it along with the plastic shifter plate/cover cause its cracked.
Have any of you guys done that?
thanks!
thanks!
Car: 1986 Irocz28
Engine: 305 tpi
Axle/Gears: stock
Re: Auto shift **** removal...?
ok this is how i took off mine. i started twisting it off counter clockwise and it eventually came off. its really not too hard.
Car: 89 Iroc Convertible
If you have the round shifter ball you must first pull out the button and there will be a c clip on top of the metal shaft that you have to remove.Once you remove the clip then you will be able to take off the ****
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
Well since someone already made a topic, I have a 84 firebird auto. My shifter is a T shaped shifter with a button on it. How would I remove one like this?
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
Sam, look at the front side (towards the front of the car/radio) of your shifter, there will be a clip that looks kind of like a staple in there. Just use a screwdriver and pry that out then the shift **** will just pull straight off. Be careful when taking the clip out, they sometimes like to go flying, don't wanna lose it.
On the front edge of the **** there should be a slot that has a horseshoe type clip inside.You need to pry it out with a thin flat bladed screwdriver.Once its out the **** should come right off
Car: Purple & Black 1984 Trans Am T-Top
Transmission: Automatic
Also, if I buy a new ****, will it most likely come with this clip?!
So if my shift **** comes off and on and spins around and around and doesn't catch because it is not installed properly, is it safe to say that this is probably because I am missing this horseshoe clip.
I don't really care...new, used...doesn't matter to me. I was looking buying a new **** online but if I can get away with just the clip, I'd rather save $ and do that. Can I get a clip at regular auto parts store, or somewhere else that is most likely local? Any suggestions?
Quick question along the same lines. I have an auto ( sad, I kno...) T-**** with the U-clip, after I remove it how do I attach an After Market ****? They usually screw on n I imigine there r no threads as it uses a clip, and the new **** def doesn't have a slot for a clip lol. Thx in advance.
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Pretty much all the mid to late 90s GMs used the C clip for the shift handle. Most of the Handles are interchangeable. Just hit the yards last weekend and got a nice black leather wrapped t handle from a Cavalier z-24. Fits like a glove, also got a pair of outside window sweeps and a rear view mirror with map lights from a 96 Camaro. All for $25.
Car: 1982 Camaro Berlinetta
Engine: LG4
Transmission: One that shifts hella hard
How'd you get the c-clip off of the shaft? it doesn't look like there is enough room for it to slide off, and I'd prefer to be able to put it back on...
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
i picked up a leather shift **** from a 4th gen, looks exactly like the one from my RS just leather and is slightly longer down the shaft(giggity) got it free from one of the local yards around here that im known at, really it was because i bought a few other things but you gotta love free
Car: 1983 berlinetta T-top
Engine: Rebuilt 305
You can also buy a cir-clip (the correct name for it) removal tool, it looks like a pair of plyers, but has little nubs that fit into the holes of the clip, makes things 1000 times easier, and you can get one at any parts store for cheap.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
