would this seat fit
Old Jul 12, 2009 | 01:24 AM
3rdGenIrocZ's Avatar
would this seat fit
i drive an 87 Iroc Z/Z28. also i drive a 96 mitsubishi 3000gt. Hey what can i say. i got american muscle. had to have some asian muscle. (made sure it doesnt sound like pissed off bees in a tin can)
But the camaro seats suck hands down. sat in my friends 4th gen. they were comfy for about 10 minutes.
But my 3000gt seats are great. and they slide forward or back so much so its good for people of any height. im 6'2'' and if i adjust the seat all the way back i can barly hit the clutch in all the way. yeah they got good leg room PLUS THE ARE COMFY!! and they dont look *****.
and i noticed that the mitsubishi eclipse has the same seats, so im guessing all mitsubishi sports have the same seats
so any1 know if they fit in a 3rd gen?
Old Jul 12, 2009 | 10:33 AM
nemoose5's Avatar
Car: 1991 RS
Re: would this seat fit
I doubt it, but if you aren't bad with fabrication work you could make your own seat brackets, or maybe you might only have to drill some holes in your pre-existing ones. Do some searching around on TGO and on the web. There should definitely be some articles about that.
Old Jul 12, 2009 | 02:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it would bepend on the width of the seat and how high it sits on its track.
it will not be a bolt in deal, but with some light fab work im sure it can be done.
Old Jul 13, 2009 | 03:43 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
will they directly fit, no, but they can be installed. I used to have awesome seats from a Mitsubishi Starrion/Conquest. Those seats are GREAT, but I had to remove them because they started to look too damaged/torn up. What I did is remove the Starrion seat brackets and lined up the Fbody brackets. I was lucky that the front bolts were the same length apart in both seats. Not the rear, so I got a piece of flat aluminum and bolted it to the seat then the seat tracks to the aluminum...
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
Roblyons
Sep 12, 2015 10:29 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
