air bag wheel to grant INSTALL, & column rebuild FAQ
Re: air bag wheel to grant INSTALL, & column rebuild FAQ
Hey guys,
I had some punk try to steal my 91 camaro and he smashed up the steering column shroud pretty bad, I have replaced most of this, but I have this piece that I am not sure of where it goes, I have have the Haynes manual for it but it doesnt show this piece please if anyone can help me figure it out that would be awesome.
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
sorry, I cant see your pic. I'll try to find & upload some schematics from my service manual (1991!) for you.
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
Was it just broken around the key area? I guess the theft deterrant in the key worked, huh?
It was the whole top housing they broke through, luckily I found this forum/ guide and took it apart but as previously said, i cant figure out where that piece goes. But yeah the VATS worked, haha. It looked like he tried getting in from the blinker switch and just broke most of the plastic housing.
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
Just found this on thirdgen.org
http://www.shbox.com/1/steering_column_exploded.jpg
Let me know if this helps.
Yeah it did, it is the actuator/ dimmer switch. Do I just put the housing on first then connect it? Still learning how to read these diagrams.
Oh and thanks for the help.
Last edited by Lantern_21; Sep 5, 2011 at 10:31 PM. Reason: Needed to thank for help
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
What #?
Also try the picture on this link
http://www.autozone.com/autozone/rep...00c1528008ea2e
Its been so long since I had to mess with mine... but I think a piece fits inside that one (#21?)
Also, thank bigj350, lol
https://www.thirdgen.org/forums/tech...ng-column.html
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
Awesome, I had my car a while when the high beam switch crapped out. Only then did I realize the car had a buzzer that sounded when I left the key in it or when the door was open just because I took the steering column apart. lol
Car: 1987 Sport Coupe
Engine: 305 carb
That goes on the left side of the column. It steadies the sector gear piece that mates with the cog that the ignition cylinder turns to start the car. I was just looking at it.
Anybody know an alternative if the lock pin for the steering wheel (the one that locks against the lock plate to lock the wheel) has a broken spring??? It's a long and curvy spring that broke in 3 places from the wheel tilting, I don't think a replacement of the same would even last long... My car hasn't locked the wheel with the key out since I've owned it and I would like to fix that. I need to hop on this tomorrow so I hope someone knows something or I can find something tonight! lol
Engine: 305 carb
OK, I finally found someone who knew where this clip went, it goes in the small rectangular hole next to the ignition switch hold down pin, I put it in after the switch, hold down pin and torx bolt where in place and then the clip goes in with the large end up and toward the front, push it in all the way and then install the white plastic piece with the 2 contacts on top of the end of the clip and push all the way in. Somehow I removed it or it fell out and none of the pictures show it nor do the schematics, been driving me nuts so I thought I'd share, Thanks for the rest, made it easy for a first timer!
Car: 91 Z28
ok, so has anyone swapped a stock earlier Z wheel into an airbag equipped car? I have a nice 86 Z wheel that I want to install. do i need the grant kit- or will my wheel bolt on after removing airbag stuff?
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
So I've made that tool to pull out the pins about 4 times now. I keep on breaking the screws, I even rode my bike to the machine shop here in town, and the strongest one he said I would find that size is 304 stainless. So I bought a couple of them. They didn't bend like the phillips head screws did, but the head of the screw just twisted off.
The one on the left side of the column came out relatively easy, but the one on the right will not budge a single bit. Are there any tricks to pulling these things out? And are grade 8 stronger than 304 stainless? The guy at the machine shop told me I wouldn't find a grade 8 in that small of screw/bolt (8-32).
I'm going to check at Home Depot for some grade 8 hardware, and see if that works better, but if anyone has a suggestion let me know!
So there is no way I'm getting a punch to work, i tried, and got it to where I can strike the punch, but the way I'm striking it, I'll end up breaking something else before that comes out. I'm just going to try and drill it out or something as a last resort.
Does anyone know where I can get another pivot pin? I found one on ebay for $25, but good lord, is it made of gold?
Car: 91 RS
Axle/Gears: Posi 3.73
OK....I followed the thread step by step getting my new Grant on my 91 RS but, now I have a problem and I wanna scream.
I unplugged the airbag from the connector at the base of the steering column and now the car won't start...... No power to the starter of the fuel pump so it can prime when you turn the key to on...... I believe it is that VATS bull.... HELP!!!
I unplugged the airbag from the connector at the base of the steering column and now the car won't start...... No power to the starter of the fuel pump so it can prime when you turn the key to on...... I believe it is that VATS bull.... HELP!!! Junior Member
Car: 1991 rs
Engine: 305 bored .30
Transmission: t5
Axle/Gears: 89 iroc 9 bolt BW disc 2.73
Do vats bypass. Not too hard.. Does security light turn on when you try to start it? Does anything click when you turn the key to start? Does the security light flash when you try to crank?
Did you plug airbag back in? I'm guessing the grant weel doesnt use your airbag? By the way, Do not probe those wires. The airbag light on?
Keep me in line, some of those features may not be on your car. I'm into the 4th gens now, but my 91 car was sweet.
Car: 91 camaro rs
Car: 2011 CTS V COUPE
Engine: BIG
Transmission: FAST
Great write up !!!! I bought a 92 Camaro RS 305 for 600 bucks this week. Wouldnt start but the owners said it ran good.
Towed it home and went to work. Steering wheel was practically hanging off and I found a pin on the floorboard. Good thing I didnt throw it away.
Turns out the ignition linkage was broken and was not engaging. Went to the Oriely's and picked up a new kit. Took everything apart and put everything back together correctly the first try.
Car is now running with bypassed vats. All I need now is to replace a pulley and this is a good running car. Engine sounds good and mean.
Just did a column rebuild myself and thought I'd post a few things. First, a pic of my loose pivot pin:
Next, a picture of the four bolts deep inside the column:
Unlike OP's, mine were regular hex head (some metric size), were all tight, seemed to have some kind of anti-loosening feature (nylon lock or similar), and were retained to prevent complete removal. This may be a feature of later columns...?
Next, I decided that I wanted to prevent the pins from ever loosening again. I picked up a 4" stainless hose clamp and wrapped it around the pins, right up against the shoulder on the column:
I had to cut a slot in the upper column cover to clear the "head" of the clamp, and trim some plastic inside of the turn signal housing piece. It took a bit of finagling to squeeze it on over the clamp, but in the end it went on without too much of a fight. Here's how it looks now:
You'd never notice it unless you were looking for it, and I'm pretty sure it will never loosen up again!
Car: Maros: 89 Z28 & 91 RS
Engine: 350 TBI & 305 TBI OEM
Great Job!!!! I´ll try it the next weekend, the "special tool" to take off the wheel has a specific name? It´s hard to take off with just the arms? can I do the same with a bearing take off tool?? sorry for my english!!! I´m from Mexico, there´s no enough information here!! and I never did that before, I have a crash and The Air Bag Explode so I wanna change the wheel!! It looks Awesome like that!!!!!
Car: 83 Firebird Trans Am
Engine: 305 LU5 Crossfire Injection
My pivot pin puller broke inside of the right side tilt pin. Oh man. It won't drill out either. Think I may replace the column now.
Car: 91 IROC
Engine: 5.8L V8
Transmission: lame automatic :(
ATTENTION!
Save yourself the headache. Before you begin, go to your friendly neighborhood auto store and borrow a steering wheel puller and a steering wheel lock plate remover.
I got the lock plate retaining wire out with a clever balancing act, but getting it back in was a bear. Man, that was fun! Get the right tools for the job!
Car: 91 Camaro rs
Engine: Tbi 305
Transmission: Wc t5
Axle/Gears: 373s
How do you get the air bag light to stay off once you remove the air bag switch? Mine just stays on. Great info and write up. Thanks
Car: 91 Camaro rs
Engine: Tbi 305
Transmission: Wc t5
Axle/Gears: 373s
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Aug 26, 2015 08:17 AM
