Center console repair
Old Aug 8, 2009 | 01:51 AM
Njs305t/a's Avatar
Car: 1987 Trans Am
Axle/Gears: 2.73 posi
The vinyl on the center console of my T/A is pulling apart. What should I use to put it back together? I realize this is a common problem and I searched but the search engine on this site is terrible. Thanks
Old Aug 8, 2009 | 03:32 AM
Gfezz's Avatar
Re: Center console repair
I just happen to be almost ready to attempt this same repair for '84 TA
console lid. Kinda have a plan, key items will be heat and gorilla glue .
The creative part will be gripping the edge of the vinyl to pull and stretch it
into place without ripping it while holding long enough for the glue to set.
I have an adjustable heat gun to soften the vinyl with, if I have luck I will post some pics, if not I'll tell you what doesnt work....
Old Aug 8, 2009 | 11:45 AM
Njs305t/a's Avatar
Car: 1987 Trans Am
Thanks I'm having a problem with that to so let me know how it turns out but I meant the whole center console not just the lid.
Old Aug 8, 2009 | 11:56 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Ive heard of other members using those large wooden clamps, that have the long threaded rods, that pull 2 pieces of wood towards the center, put gorilla glue, or similar between the vinyl, and plastic console frame, and clamp them down.
Ive never personally tried thos, but sounds like it could work.
Old Aug 8, 2009 | 12:10 PM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Go to the auto store, & get some 3m spray adhesive. It is similar to factory, & they have 3 strengths to choose from. gorilla is a good glue but in areas that are hard to keep in place you will just end up pulling your hair out. GG will also dry, & just be a huge lump of crap, so if you dont get it right the first time, you will have more fun removing the GG.
Old Aug 8, 2009 | 01:46 PM
Njs305t/a's Avatar
Car: 1987 Trans Am
The previous owner put liquid nails in to try and hold it together. It worked somewhat. Should I try and get it out before putting anything else in?
Old Aug 8, 2009 | 07:13 PM
STRIKER911's Avatar
Car: 89 RS
Oh wow. GG is more like liquid nail, so you see the trouble now before you have to learn the hard way, like I did. Yes try to get it off, if you can. If not you will have a build up of dry LN making it harder to adhere it.
Last edited by STRIKER911; Aug 8, 2009 at 07:17 PM. Reason: Post a picture if you can, so we know exactly what your working with too.
Lbibb
May 5, 2016 12:00 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ndndndnd
Sep 28, 2015 08:00 AM
