Part broken, but can't find it!! HELP!!!!!
Old Aug 19, 2009 | 02:23 PM
jliner's Avatar
Car: 91 Z28 T-Top
Engine: 305 LB9
Hi there! First of all...I'm new to the forum. I'm from Colombia (South America ) and I'm glad to be here to share experiences and learn.
I drive a 1991 Z28 and have my turn signal lever - and the box where it pluggs in - broken.... The last one it's my problem: I've searched a lot and found that maybe that little box is called "Pivot and Pulse Switch". However I can't find it anywhere on the internet or catalogs.
Because I'm the second owner of the car, I don't know if that box is an original part of the car or if it's a part that was incorrectly put to fix the turn signal assembly.
If you know about this part, if it is an original part and where I can buy it from, I would appreciate it a lot!
PD: Hope you understand my English!
Thanks again.
Old Aug 19, 2009 | 06:03 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Part broken, but can't find it!! HELP!!!!!
Thanks again.
Hard to tell by just text. See if you can get a picture of the broken part, so we can have a good idea of what exactly it is.
Old Aug 19, 2009 | 06:28 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
If it is what the the wires off the turn signal lever plugs into it is PN# 26017185 and it cost me $110.90 USD. Dose it run down the steering column and plug in the bottom close to the fire wall? I could only get it through GM you might try Hawks I know they will ship Int.
Old Aug 19, 2009 | 09:45 PM
jliner's Avatar
Car: 91 Z28 T-Top
Engine: 305 LB9
Thanks for your answers... I was looking at some pictures for PN# 26017185 on the internet, but I'm not sure if that's the one (pics are not so clear).
Maybe tomorrow I can take a pic for the broken part.....Meanwhile, below there's a diagram I found just for the part I need:
This is the pic for part PN# 26017185
Old Aug 20, 2009 | 07:26 PM
Car: 1992 camaro
Axle/Gears: 3:73
Well that pn I gave you is not what you need. I have a buddy that works at a local dealership I'll call and see if he can give me the pn.
Old Aug 20, 2009 | 08:38 PM
jliner's Avatar
Car: 91 Z28 T-Top
Engine: 305 LB9
I'll appreciate it!!!
hectre13
Dec 11, 2023 08:14 AM
twest2k2
Aug 24, 2015 11:26 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
