window problems
Old Aug 30, 2009 | 07:51 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
window problems
Seems I opened a can of worms on my 87 ta with electric windows. I was going to try to adjust my drivers side window because it had alot of flop to it. Here is what I have found.
Problem #1 lower stop gone. FIXED with bike brake pad
Problem #2 upper stop broken(see pic). Anyone make a replacement or do I have to rumage thru the junk yard? Do I just drill out the rivet, replace and rerivet?
Problem #3 regulator and motor. This seems to be a couple problems in one.
First, the upper rivet hole is cracked(see pic), how can this be fixed?
Next, when the window reaches the stops it seems to want to push a little more. When it does this I can see the rivets move (rivet holes that hold on to the regulator elongated) and I can see the sheetmetal that the regulator connects to flexes. What is causing this to happen and how can I remedy this?
KeithO
Attached Thumbnails window problems-100_2185.jpg   window problems-100_2186.jpg
Old Sep 1, 2009 | 07:40 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
Re: window problems
any thoughts?
Old Sep 19, 2009 | 01:59 AM
kittca's Avatar
Re: window problems
That happens with these 3rd gens. You may want to install new window motor and regulator. Dont worry about 1 rivet. If you cant fix it, take it to an automotive window install shop.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
neekolzun
Aug 24, 2015 04:59 PM
