Door Panels
Old Sep 13, 2009 | 11:13 PM
91project's Avatar
Car: 1991 Camaro RS
Engine: 305 c.i. T.B.I.
Transmission: TH700R4
Axle/Gears: stock open 2.72
Door Panels
I'm making door panels for my Camaro, and i wanna know what type of backing board you guys recommend i use?
any input would help
Old Sep 16, 2009 | 07:46 AM
Jeff87ta's Avatar
Car: 87 Firebird with T-tops
Engine: 350 finally!
Transmission: 4spd auto
Axle/Gears: sometimes I get traction...
Re: Door Panels
I used MDF. About 5mm thick, I think.
Old Sep 16, 2009 | 03:01 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Door Panels
1/8" MDF or OSB (hardboard). Then just cut out your template.
Old Sep 19, 2009 | 02:04 AM
kittca's Avatar
Re: Door Panels
ABS platic, 1/4" thick, let a professional plastic company do the job.
Old Sep 19, 2009 | 12:32 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Door Panels
If you've got the cash,. They'll last a lot longer. If your on a budget the other suggestions will work just fine.
Old Sep 19, 2009 | 03:00 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: Door Panels
I'm using 3/16 masonite for mine
Old Sep 19, 2009 | 03:05 PM
Re: Door Panels
I used to restore antique radios from the 30's-50's and I can say that masonite does NOT last. Most radios used it as a back and it deteriorated from heat of the tubes. That being said I don't know how well it would hold up in the heat of a car. I also don't know if/what improvements have been made in the last 70 years so I guess I'm just talking yer ear off.
Old Sep 19, 2009 | 05:15 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Re: Door Panels
They do that? Sweet!
Old Sep 19, 2009 | 09:15 PM
91project's Avatar
Car: 1991 Camaro RS
Re: Door Panels
Yeah i don't really have a hole lot of money but i think i'm going to head to lowes and pick up some 1/8" plywood, anybody know about how much the abs would cost, i'm gonna cover them with some black vynol that i picked up from jo ann fabricks, the actually have a decent amount of things in there for interior like headliners and things
Old Sep 19, 2009 | 10:58 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Door Panels
I remember a company called "RodDoors" yrs ago made them on ABS in different patterns, from flat to flamed to scallops etc for the ledsleds,coupes,deuces in different lengths & hights.IDK if that would interest you..?..
Old Sep 20, 2009 | 03:32 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Door Panels
what is MDF and does anyone got pics of their own made panels?
interesting..
i may have to do this for my 82
Old Sep 20, 2009 | 04:38 PM
jim91gta's Avatar
Car: 1991 GTA
Engine: 5.7
Re: Door Panels
handi-board. comes in 1/4 or 1/16 thickness. 2x4 for 3 bucks. or 4x8.Then you can put foam/fabric from fabric store.
Old Sep 20, 2009 | 07:20 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: Door Panels
interesting..
medium density fiberboard, the stuff most sub boxes are made of. absorbs water like a sponge.
Old Sep 20, 2009 | 09:23 PM
91project's Avatar
Car: 1991 Camaro RS
Re: Door Panels
but if you hit it with some waterproof spay paint it seals it pretty good, i've made plenty of speaker boxes for people, so i figured i'd give making door panels a try
Old Sep 21, 2009 | 11:21 PM
91project's Avatar
Car: 1991 Camaro RS
Re: Door Panels
I went into home depot today and what i found was some 1/4 plywood, it's not MDF it's plywood. which i thought was perfect so i get one of the workers there to see if they would cut a piece in half so i could get it home (I only got my Camaro) and the guy took me over to some smaller size board and i found the perfect size board all i have to do is trim the corners, i'll post pics tomorrow
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
