Custom 1990 Dash For Autometer
Old Sep 14, 2010 | 12:28 PM
  #51
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: Custom 1990 Dash For Autometer
Originally Posted by MrPhotographer0
pwdbychevy, what size are your holes you have cut?
Big holes are 3 3/8" and smaller holes are 2 1/16". Here is what they look like now.
Old Sep 14, 2010 | 04:10 PM
  #52
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
checked out your car, pwdbychevy, on cardomain, really nice man.
Old Sep 14, 2010 | 06:21 PM
  #53
pwdbychevy's Avatar
Old Sep 14, 2010 | 08:25 PM
  #54
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
nice. yeah, i checked out your car a while back. Hes my schematic for 82-90
Old Jan 5, 2011 | 01:33 PM
  #55
1BADZ28SD's Avatar
Engine: 5.7Liter HSR
vrey nice they look like mine mines carbon fiber tho Name:  100_0165.jpg
Old Jan 5, 2011 | 01:35 PM
  #56
1BADZ28SD's Avatar
sorry forgot to do the tach went i took the pick Name:  100_0175.jpg
Old Jan 19, 2011 | 06:41 PM
  #57
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
does the autometer gauges hook right up to the stock wiring for your gauge cluster...like are there wires for the speedo that the autometer speedo can connect to etc.
Old Jan 19, 2011 | 06:52 PM
  #58
pwdbychevy's Avatar
The speedo connects to the vss directly. The tach can be spliced into the factory harness. The oil pressure and water temp connect to their own supplied sensors and not in the factory connectors. The voltmeter can be spliced into the factory harness as well as the fuel gauge. You will need a wiring diagram for the factory cluster to find which wires to splice into.
Old Jan 20, 2011 | 09:15 AM
  #59
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
It is really that much of a pain in the a**?
Old Jan 20, 2011 | 09:16 AM
  #60
Engine: L99 L98
That is "fargin" nice though!!
Old Jan 20, 2011 | 11:43 AM
  #61
Engine: 383 stroker
I was wondering if I I got a mechanical speedo what would I need to do to make it work in my car concidering I have an electric setup already, I only ask because I just got a good deal on some autometer z series fuel, volt,water temp, and oil pressure gauges and if I got a z series speedo and tach to match the speedo only comes as a mechanical setup.
Old Jan 20, 2011 | 07:36 PM
  #62
pwdbychevy's Avatar
I'm not sure about the mechanical setup. I would imagine if you can hook up a cable to your tranny to get a reading then it will work but I would contact autometer tech support to make sure.
If you're a novice to wiring diagrams then it can be a PIA. There is cutting splicing into the factory harness involved. If you're not sure what to do just ask for help. The hardest part for me was running the oil pressure sensor wiring through the firewall and finding a location for the oil and water temp sensor.
Old Mar 22, 2011 | 01:33 PM
  #63
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I know this is sorta an old thread, but I too run 3 3/8" tach and speedo. I emailed classisc dash about their 90-92 gauge panels. They dont have a blank panel or a panel predrilled for 3 3/8" gauges listed on the site, however, if you email them or call them, they will sell blank panels or predrill you a panel for whatever size gauges you want. Theyre still $159 for either way.
Old Mar 23, 2011 | 12:05 AM
  #64
Engine: L99 L98
Yes, they are cool cats there and I want to thank them again for doing it for the 90-92 crowd Thanks Greg @ Covans !!!
Hotrodboba400
Dec 10, 2019 07:07 PM
MantyZ28
Nov 8, 2015 06:54 PM
Ian Irvine
Sep 4, 2015 08:08 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
