Door speakers
Old Oct 2, 2009 | 08:41 PM
DirtDawg57's Avatar
Door speakers
Has anyone tried to mount speakers in the doors like on the 4th generation? I did a search and didn't find anything but I have a hard time believing that with all the creative genius in this forum no body has tried this. I haven't taken my door apart yet so I don't know how its designed but I saw somewhere that the power windows motor is where the speaker would be on the 4th generation but what about a little farther back?
Old Oct 3, 2009 | 12:56 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Door speakers
yes, its quite common. I have speakers there. You probably didn't search the right thing because you simply cannot mount the speakers in the door. You have to make a door pod to put the speakers in.
Old Oct 3, 2009 | 03:52 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Door speakers
i did, you can mount 5,25 there... i needed them flush since i have manual windows lol
Old Oct 3, 2009 | 04:24 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: Door speakers
got any pics? I'm not sure if its possible with electric windows since I believe the window motor sits in that general area...
Old Oct 3, 2009 | 05:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Door speakers
I got a set from a newer caddy at the JY - they stick out from the door a tad because of the window motor issue, but the caddy has really nice black carpeted 'pods' factory made on the door that I also got hold of - maybe some day I'll have time to try it out and see if it fits.
Old Oct 4, 2009 | 08:43 PM
DirtDawg57's Avatar
Re: Door speakers
I was wondering if you cut a circle right behind where the power windows motor is mounted if it would fit there, but I'm not sure if it will get in the way of the linkages or the window coming down.
Old Oct 6, 2009 | 07:23 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Door speakers
you definitely need spacer in order to not hit the window motor. Also, our door panels are not a very rigid material. To do it right, you really need to build up a pod and bolt it directly to the door sheet metal. Not overly difficult, but not as easy as just throwing in and going.
Old Oct 6, 2009 | 07:35 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Door speakers
You can make door buildouts (see below) or use spacers and buy "shallow mount" speakers. 5.25 or 6.5 speakers will work.
Two 6.5" with power windows Name:  SDC11081.jpg
Spacer ring
http://www.parts-express.com/pe/show...TOKEN=48616562
Old Oct 7, 2009 | 05:44 AM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Re: Door speakers
It's not too hard but as others have said, you will need to make spacers, here's a pic of mine
Old Oct 8, 2009 | 09:23 PM
DirtDawg57's Avatar
Re: Door speakers
Those look really nice, thanks for the pics! I'll have to start thinking up some ideas.
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
codeysabatini
Sep 20, 2015 11:36 AM
84 TA NV
Sep 6, 2015 08:02 PM
