Manual Shift Booth On Automatic?
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Hey Everyone,
I always liked how manual transmissios have the booth and everything. I been wanting to buy a stock manual booth and plate to put it in my automatic, has anyone done this before?
Post Pics if so.
Thanks. Tony.
Post Pics if so.
Thanks. Tony.
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: Manual Shift Booth On Automatic?
I had the same idea!!!!!
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
I did this on my Mazda 3... It looks the part if you can get the boot over the bezel. You can pick up universal shift boots (black w/ red stitching) at autozone for under 10 bucks... Why not give it a try?
Engine: 3.0L 2JZGE
Wouldnt that be a nice a.s.s. mod? Now to find a booth.
Tony.
Tony.
Engine: 3.0L 2JZGE
I havent come across with someone that has done this. I have been thinking of this idea for a long long timenow/
Tony.
Tony.
Car: 91 camaro z28
Engine: 355
Axle/Gears: stock
its actually really easy..and looks amazing on mine..ill get some pics..i also have a manual shift *** on it which helped with my grip, considering i have sweaty palms and those t shifters dont cut it for me.
Ill try and get pics tonight assuming my camera is charged.....but take my word for it..it looks REALLY nice..i love it
Engine: 3.0L 2JZGE
Nice, finally someone with my cool mod that I been thinking about for a while but havent had time for it. So how is that you were able to fit a manual shift ***? So how would you go on where abouts on chaniging gears?
Thanks. Tony.
Thanks. Tony.
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Cool Idea, Good luck finding one, they are really hard to find!
Car: 91 camaro z28
Engine: 355
Axle/Gears: stock
well its not hard at all..take off your outer plate..which exposes the shifter(depending on ur shifter), slip the boot around it..and depending on what shifter you have..you can put the poot over the button or pull leaver..or cut alittle slit in it. i have it over..to hide it..but i can pull it with it on...because you can feel it under it. Get a universal fit one though..dont get car specific. Then the ***..what i did was unscrewed my T ***..put the manual one in it..and put washers over the screws so it fights snug then tightned the screws..and i will never go back honestly. Tomorrow..ill take it apart..take all new pictures and show you how to do it. Now im not sure if its different on different kinds of shifters. So keep that in mind
Car: 91 camaro z28
Engine: 355
Axle/Gears: stock
wow stupid me..i should have asked you this first..haha..are you running a stock shifter? or an aftermarket one..keep in mind..im using a b&m shifter..so now that i think about it..i think its alot different haha.
Car: 87 GTA
GM beat ya'll to it, back in 1987. That is the way my 87 GTA came stock. Shift boot instead of a slider & the PRND21 pattern beside the shift boot.
I want a 4th gen console, but only if it is from a T56 car.
Car: 1992 RS
Transmission: Automatic
Gotta get it on this for the camaro, sooo...
No idea bout the shift ***. Would have to buy a boot and **** around to see if it to see about the fit
Car: 87 GTA
Just put a T5 console top on guys! Really.....That is all there is to do the swap.
Engine: 350TPI/ S50
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Car: 1992 RS
Car: 87 GTA
Car: 1992 RS
Oh, you just mean one of these babies, mah bad!
See, i thought about that too. But hate how it would have the manual icon there and be missing the auto gear indicator, so you wouldn't be able to see what gear you're in.
Found this though, addresses the problem i have, iif it could work.
That's more along the ideas of the kind of mod I was thinking about.
https://www.thirdgen.org/forums/inte...-interior.html
Car: 87 GTA
Here is my BONE STOCK 87 GTA, manual booted, 700R4 shifter console.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You can always modify the stock unit & make your own boot.With real leather to boot(pun).
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks, Not too difficult either.I did this way back in 96.Thats the 2nd boot Ive had to make.First one cracked from all the folds after some 5-6 years.Topped it off with the Ind window from a Berli after i made the second boot.
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Car: 87 GTA
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Ive seen them on 91 GTAs.So im guessing all automatics up to 92 had the boot.
I tried cutting that section out to graft on the camaro piece.Too much work though.
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I have yet to see a 3rd gen Firebird WITH a slider, I thought all of them came with boots (both manual and auto)...maybe not the early 3rd gens, but definitely the later...
Engine: 3.0L 2JZGE
Once again Rick you impress me this is the perfect mod I been thinking but way much better cause I wanted the actual 5 speed plate and everything.
Thanks. Tony.
Thanks. Tony.
Engine: 3.0L 2JZGE
Thanks. Tony.
Engine: 3.0L 2JZGE
Hey Rick,
Could you PM me with the pics cause here at work they dont show on the computer or either you delete them or so.
Thanks.
Thanks.
Engine: 3.0L 2JZGE
Hey Rick,
Im guessing at work they dont let me view the pictures, dont know why but I saved them on my comp. Hey your shifter ball what year did those come in? Is it possible to modif a manual ball into our shifters?
Thanks Tony.
Thanks Tony.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
That shifter **** is stock for that year.I think only the Z28 got it leather wrapped though.Maybe up to 87 before they switch to the T-handle, not sure though.
Engine: 3.0L 2JZGE
Hey Rick,
The shifter **** I have is the one that came on the 91-92 camaros since mine is a Z28 it came leather rap. Today my friend is over at the hollywood junkyard and hes gona pic up a ball type shifter **** like yours and hes gonna get me a nother shifter plate since myine has broken corner.
You said that your shifter indicater came of the berli?
Thanks. Tony.
Thanks. Tony.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Only the window is from the berli.Its a very thin strip of plastic.The rest of the shift ind is original.The berli's is black w/white letters.The blue is from the ind window, not so much from the LED
Engine: 3.0L 2JZGE
Hey Rick,
Gotcha man So you just changed the platic with the letters im gonna try to do this mod when ever I get some time or so. So you were saying that you made your own leather booth? Is it easy by the way?
Thanks. Tony.
Thanks. Tony.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It was'nt too hard.I copied it from one i found at the JY though.There are universal boots you can use too.
Engine: 3.0L 2JZGE
Ohh ok I'll see next time I go to the junkyard to look out for some.
Thanks. Tony.
Thanks. Tony.
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
I got one of those black/red leather boots from auto zone and stapled it to the bottom of the plastic cover plate. I got some PVC pipe and fandagled a way to attach a HURST T-handle shifter to my auto transmission instead of the stock shifter. I don't have a button this way but I have to push the shifter down to shift. It sounds ghetto but actually works pretty well. I'll post some pics tomorrow.
Engine: 3.0L 2JZGE
Thanks. Tony.
Car: Trans Am
Engine: V8 350 TPI
wow that looks so f****n clean
can someone post like a step by step guide on how to do this..
it would be super helpful..
thanx ahead of time
thanx ahead of time
Engine: 3.0L 2JZGE
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Engine: 3.0L 2JZGE
Hey Rick,
Im pretty sure he was talking about you.
Tony.
Tony.
