Z/28 Interior Options...
Old Oct 20, 2009 | 02:38 PM
Jimmy D's Avatar
Car: Camaros and Suburbans
Engine: V8's
Hey Guys, I have a question for a friend that I don't have the answer to;
There is no RPO sticker in the center console: but this car appears to be a Z/28 optioned Camaro made in California in 1984; (1G1AP87H7EL) T-Tops with the overhead console, (map light - pocket - trip estimator, etc), dual snorkel 5.0, front disc / rear drum, 700R4, big sways and springs; they all appear to be original-equipment parts on his car.
My question, is there some additional location to find the RPO info other than the center floor console glove box on these cars?
Old Oct 20, 2009 | 05:06 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Z/28 Interior Options...
Probably not. Sometimes there will be a build sheet stashed under the carpet, but it's a crapshoot. It just depends on whether or not the people building the car that day tossed it in the trash, or in the floor of the car.
Old Oct 27, 2009 | 10:22 PM
Jimmy D's Avatar
Engine: V8's
Hey Ward,
Thanks for your input on this, he'll have to figure out some things about this car. He is on a quest to get his car together.
Thanks again,
Old Oct 27, 2009 | 10:58 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
im not sure if an 84 has this, but have you checked the rear hatch compartment??
Old Oct 28, 2009 | 06:50 AM
85 Z28's Avatar
Car: 85 Z28 Camaro 2011 camaro LS
Engine: 350 Edelbrock Crate bored .60 over
Transmission: 400 turbo
their really is no place to find out other than the center console or the build sheets what he can do their is a web site were you pay 50 dolars and the send you a repro of the original window sticker you will find out alot about your car with that window sticker and its also nice to have if he ever deceided to put the car in a car show other than that he can try going to his local gm dealership and the can try to run his vin through gm vis he might get lucky because usualy it shows the trim level of the vehicle and if he had any recalls which their is one on 82 through 89 camaros on the seat belt retractors and buckles also on the parking brake
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
sylentnite
Sep 9, 2015 02:55 PM
