what color is this?
Old Nov 2, 2009 | 10:03 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
what color is this?
What color is this and where can I get replacement interior parts the exact same color?
I have checked Classic Industries and no luck. YearOne sells a "russet" that looks kind of like it but they won't send me a sample swatch to compare.
EDIT: Car in pictures is 1985 IROC. I am trying to figure out the interior color, but it does closely match the exterior paint as well.
Attached Thumbnails what color is this?-hpim1322email.jpg   what color is this?-hpim1323.jpg
Old Nov 3, 2009 | 09:20 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: what color is this?
Hey, if you're interested, we can send you some samples to match up. PM me with your contact info and we'll get some out your way.
Old Nov 3, 2009 | 09:44 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
For '87 i believe it was carmine red. But there are also many names for the same colors it seems as different sources online reference the colors differently.
Old Nov 3, 2009 | 10:52 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
It's not carmine red. Compared that with samples and it is very different.
Old Nov 3, 2009 | 12:47 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
The "Camaro White Book" lists the interior colour in 87 simply as "Red".
There were four colour choices - Black, Grey, Saddle and Red
Old Nov 3, 2009 | 09:12 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
My bad, the car in the pic that I am referring to is an '85 IROC.
Old Nov 4, 2009 | 12:09 AM
Car: 89 IROC
Camaro White Book states "Red" for 85-92.
Looks like there is only one red description for the Camaro.
Old Nov 4, 2009 | 05:59 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Hard to tell but are you sure it's not copper?
Check the code inside of the center console box if it's still there.
Actual information
on inside of center console on RPO label: WATER L8607 U8607
http://www.automotivetouchup.com/gmlabel.htm
http://www.camarosource.ca/php/camar...trim&year=1985
69E / (WA 8591) Copper Metallic Bc-Spc-Zc BK-C-S 11,406
Paint Codes for 1985 Chevy Camaros
Year Code Exterior Color
1985 11 WA 3967 White
1985 12 WA 8535 Silver
1985 15 WA 8573 Medium Gray
1985 19 WA 848 Black
1985 26 WA 8596 Dark Blue
1985 30 WA 8587 Bright Blue
1985 50 WA 8740 Yellow Gold
1985 54 WA 8525 Light Yellow
1985 60E WA 8590 Light Chestnut
1985 60W WA 9606 Light Chestnut
1985 69E WA 8591 Russet
1985 69W WA 8607 Russet
1985 75 WA 8537 Blaze Red
1985 78 WA 8524 Dark Red
Sometimes copper is listed as russet.
Old Nov 4, 2009 | 07:17 AM
Car: 89 IROC
To the OP (Aaron R)...are you asking about the interior colour?
I assumed you were as you posted this question in the "interior" section of the board.
FYI...."Copper" exterior colour did not come with a red interior option.
Old Nov 4, 2009 | 07:33 AM
Scorpner's Avatar
Engine: V6, V8
I added the exterior info because the interior is often custom with copper. It also shows the connection sometimes between copper and russet.
Old Nov 4, 2009 | 07:54 AM
thecraze's Avatar
Also, you have to consider that the age of the car faded the color somewhat. So, if you get the original color in new condition, it'll be bolder than what you have.
Old Nov 4, 2009 | 08:04 AM
84redta's Avatar
The only reason i brought up carmine red is because my '86 Berlinetta interior looked very similar to that. Although i cannot tell if it's age or not, but that interior seems a bit brownish red. I say try samples from 1A above and that will get you closer, but as mentioned, you replace any part of that interior and it will be noticeable between age and sun discoloration.
Old Nov 4, 2009 | 10:25 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
The interior is definitely a brownish red. The RPO codes I have are :
-68C "Trim combo, cloth, Dark Auburn
-68I "Interior trim, Dark Auburn
-689? "seat belt color, dark auburn"
-69L "secondary color, exterior, rootbeer met"
-69U "primary color, exterior, med beechwood met"
The codes themselves I pulled out of the car. For the "interpretation" of them I referenced a couple different RPO lists online.
I haven't seen a "Dark Auburn" for sale anywhere. The color is faded a lot in places, but the kick panels and door panels all match closely the carpet color underneath the seats where the sun has not faded anything.
I could order color samples from 1A but I won't get them in time for my next trip to Classic Industries. Trying to get this figured out before then. Thanks for help!
Old Nov 4, 2009 | 03:50 PM
Scorpner's Avatar
Engine: V6, V8
FWIW I have the following, never looked them up though. I did buy mine from the original owner and he referred to it as copper. Don't recall if there's any paperwork. I've had the thing since '97. Plastics, carpet, seat belts, headliner, door panels and seats are all orangish/copper.
-68(B) But my door panels are not cloth.
Old Nov 4, 2009 | 09:40 PM
felix1771's Avatar
Car: 1991 trans-am convertible
Engine: mini ram 358 sbc
Transmission: mega raptor 700r
Axle/Gears: moser 12 bolt 3.73
I have a 1985 firebird that has burnt orange interior(could be russet) map pocket,seat belts and all the plastic"s the whole interior. The seats are bright orange with a silver stripe down the middle of the seat front and back. just sharing and its not a faded brown,tan or red interior.
Old Nov 5, 2009 | 02:19 AM
osso12's Avatar
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
Its the same color as my 85 z.
That color of the IROC you posted is a Z not an IROC BTW.
it maybe be hard to find parts for your interior as its not a popular color.
I need a front seat cover and seat belts as well.
Old Nov 5, 2009 | 02:22 AM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
I call it Copper, but I believe it is actually Russet
Old Nov 5, 2009 | 10:57 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
That is the exact same color. Even the seats are the same color and pattern. I guess Russet is a pretty hard color to find. Thanks for the pics! I can't seem to find door panels or seat upholstery in that color. I think I located all other parts in Russet though.
What do you mean? I thought all IROCs were also Z28? (but not vice versa)
The "IROC-Z" on my door panels definitely look original. The "Z28" RPO code is obvious. Is there an "IROC" RPO code?
Old Nov 5, 2009 | 11:25 AM
Scorpner's Avatar
Engine: V6, V8
Wow, a convertible!
Here are the seats and door panels on mine:
Old Nov 6, 2009 | 12:19 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Interesting. I guess that is the standard trim. I have the "deluxe" trim. Always wondered what the difference was.
Old Nov 6, 2009 | 04:26 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
i believe you are correct. the irocs ground effects always match body color. a iroc is always az28 but a z28 is not always an iroc. a z28s ground effect will always be two toned.
Old Nov 6, 2009 | 04:37 PM
Wolnam's Avatar
Car: 87 Camaro Sport Coupe/ 89 GTA
Engine: 2.8L V6/ 5.7L 350 TPI
All I can say is that the colour is gross. If I were you Id swap it out for something all together different.
Old Nov 6, 2009 | 08:14 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The interior is Copper. The exterior color is copper. In 1985, this interior was only available on the Berlinetta, Sport Coupe and Z28.
As for the Z28/IROC-Z issue, you are partially correct. In 1985-1987, the IROC-Z was an option package on the Z28. The only way to get an IROC-Z was to get a Z28 with that option package. In 1988, Chevy streamlined the model lineup and because of the popularity of the IROC-Z, made all Z28s an IROC. You could no longer have a Z28 or an IROC-Z, they were one in the same. The RPO code for an IROC-Z in 1985-87 was B4Z. In 1988-90, The RPO code was just Z28.
Old Nov 7, 2009 | 12:15 AM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
I'm glad that's settled.
Where can Aaron R. and I find replacement interior or covers ect for copper interiors?
Old Nov 7, 2009 | 10:27 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Update on this. Yesterday I found this carpet color on ACC's website and went back to Classic about it. They had to put it in their computer system and then were able to special order it for me. ACC calls it "Russet" and it is color #4896.
While I was there I matched a sample of my old headliner to Classic's "Russet" headliner material and it is an exact match. So I bought headliner material, sail panels, and sunvisors in Russet.
So, the only interior components I really have to replace now that I haven't located Russet color for is the upholstery and the door panels.
Old Jun 9, 2017 | 01:03 AM
DeDavis's Avatar
It is Copper/Russet. It was only available in the Z-28 option, not the IROC. The seats came in a russet/saddle combination velour cloth seat. It is pretty much not available since there were only 11,406 of them made in 1985. If you can find it, let me know. They reference in multiple places copper/russet but it is the same color.
Old Jun 9, 2017 | 01:18 PM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
zombie thread
Old Jun 9, 2017 | 02:39 PM
DeDavis's Avatar
Hahaha, yes it may be but I just saw it!! Looking for interior parts for my car.
Old Jun 9, 2017 | 03:03 PM
jworks's Avatar
Engine: 5.7 liter
I'm a firebird person but taking the info from this thread and a quick search on the ole inner webs I'd say it's russet. they made similar exterior color for the birds, it's rather uncommon.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Linson
Oct 1, 2015 09:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
