Window Motor Replacement
Old Nov 9, 2009 | 09:25 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Hey guys. I need to replace both window motors on my 88 GTA and need some advice. I was doing some work inside the doors last weekend and cleaned and lubricated all of the tracks and moving parts of the window regulators. While I was in there I noticed that the window motors are original! I'm impressed that they still work at all but they are very slow and need to be replaced. I was looking at how the regulator/motor assembly fits in the door and it looks like I should be able to replace the motor without removing the entire regulator assembly as long as I secure the spring. Does anyone know if this is possibe? Has anyone tried this? It might be a horrible idea but I'd like some input from other thirdgen owners. Thanks!
Old Nov 9, 2009 | 10:00 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Window Motor Replacement
There is a thread about window motor replacement that states something in the title about "tech article is bogus" or something like that. There is a template in the thread of where to drill holes and remove the motor without removing the regulator or any other pieces. I've personally done it this way on my car, and it was very easy and quick, and it all worked out very nice - and 3 years later it's all still great. Do a search for window motor and you should find it.
Old Nov 9, 2009 | 10:01 AM
Car: 1992 RS
Engine: Carbed 350
Never ind the search - here it is:
https://www.thirdgen.org/forums/body...tall-easy.html
Print out the template, place it on your door, and follow the instructions - it's a great method! And ignore the talk of it being a "hack" job - it really worked out extremely well!
Old Nov 9, 2009 | 12:10 PM
Car: 1988 GTA
Thanks a lot! You just saved several hours of frustration. I looked closely at how the regulator assembly works the other day and it seemed like there had to be a better way than they give you in the tech article. The haynes manual is worthless for this job. They literally tell you to take the car to a shop. Thanks again!
Old Nov 9, 2009 | 12:53 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You can easily pull out the entire assembly then remove the motor from it. Either way, the hardest part is re-installing the motor using the nuts/bolts that are supplied to replace the factory rivets. When I did one using the bolts (instead of new rivets) I used some JB Weld to hold the nuts onto the back of the motor housing. There is NO room to finagle and hold these bolts back there by hand when re-installing.
Old Nov 9, 2009 | 01:45 PM
Car: 1988 GTA
Good idea with the JB Weld. Thanks for the tip.
Old Nov 10, 2009 | 03:48 PM
1Aauto's Avatar
Former Sponsor
Hey welcome to the site 88gta. Not sure if you need them but we carry the window motor kits for your car. here's a link to them if you would like to check them out.
Pontiac Firebird Window Motor Kit
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 13, 2015 12:59 PM
