Speedometer wont work
Old Nov 24, 2009 | 05:47 PM
HOFF1983TRANSAM's Avatar
I have a 1983 Trans Am that has the 305. The speedometer doesnt work but i pull the front cover off and the dial rotates. I was wondering if this means the gauge is good and the cable is bad. Im think about replacing the 85mph gauge with maybe a 145 or a 160 and i wanted to know if there is anything special i need to do.
Old Nov 24, 2009 | 05:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer wont work
Take note that you'll need a mechanical-driven speedo if you wish to swap. The following link may provide some insight into your problem:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Nov 24, 2009 | 09:21 PM
Thank you for the reply im going to remove the speedometer, because the needle is broken anyways, and replace it with a new one. Do you know anywhere i can get a OEM speedometer or a pretty cheap 4" one?
Old Nov 24, 2009 | 09:25 PM
JamesC's Avatar
Do you know anywhere i can get a OEM speedometer....
Try the on-site classifieds or any bone yard.
JamesC
Old Nov 27, 2009 | 07:46 PM
k will do thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
