Manual Shifter PLate on Automatic.
Old Dec 7, 2009 | 01:27 AM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Hey Everyone,
I had this idea for a while about just putting the manual shifter plate on my automatic and today I was really paying atention to that idea that i came accross some possibly issues but not sure. I was looking on the automatic the slider goes all the way to the bottom so when you drop it in 1st. So I was looking at the manual shifter plate and theres a wider or longer part on the plate itself would the shifter hit the plate when I drop it in 1st?
I was wondering about that and i'm not sure if anyone has done this mod or so.
Thanks. Tony.
Old Dec 7, 2009 | 01:50 AM
Stephen's Avatar
Car: 87 GTA
Re: Manual Shifter PLate on Automatic.
Yeah....The factory beat you to it.
My 87 GTA came STOCK with a shift boot on an automatic. I don't know if Camaro ended up with the shifter further back or the shift boot futher forward, that would prevent the console tops from just being swapped out.
Old Dec 7, 2009 | 05:06 PM
Engine: 3.0L 2JZGE
I men the shifter itself would it hit on the manual shifter plate?
Tony.
Old Dec 7, 2009 | 07:18 PM
Stephen's Avatar
Car: 87 GTA
If you are talking about swapping the entire T5 console top over, I don't see why...Mine doesn't, unless it was DESIGNED that way & the Camaro shifter sits further back, but I doubt that..
Old Dec 7, 2009 | 07:37 PM
Engine: 3.0L 2JZGE
Yeah I want to put the 5 Speed shifter plate on my car and take my automatic shifter plate off and swap it just the shifter plate so I could ake it look like a 5 Speed.
Tony.
Old Dec 7, 2009 | 07:50 PM
Stephen's Avatar
Car: 87 GTA
You could cut your console top out & put in a boot. That is kinda how mine looks, since it has a mabual shift boot, yet there is a slider indicator next it, that (is supposed to) light up & show which gear I'm in.
The bulb is out & I've never cared enough to put a new bulb in it.
Old Dec 9, 2009 | 07:47 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I tried that when I went t56 not long ago. It looked silly, partially because the opening was too long. There also was no good way of mounting a boot so that it would look somewhat original.
Swapping the whole shift plate should work... how often do you actually drop the shifter down into first anyway?
Old Dec 9, 2009 | 11:58 PM
Engine: 3.0L 2JZGE
I have an idea on how to have it hold on the shifter and yes I do drop it in first like a couple times a day or every other day does it get on the way? Did you ever take pics of it?
Thanks. Tony.
Old Dec 10, 2009 | 06:01 PM
Engine: that I like
Thanks. Tony.
Well, i was trying to do the opposite as you. I wanted to modify the automatic plate to use with the t56. I cut out enough to completely remove the slot for the auto shifter, this made the opening look a little funky. A stock manual shift plate would likely not provide enough clearance to drop it down in first gear.
I still have my modified (cut) auto shift plate that I can take pictures of. The leather boot I got from a Volvo did not fit the opening very well, so I just bought the correct manual shifter plate.
Old Dec 10, 2009 | 07:38 PM
Engine: 3.0L 2JZGE
Damm I need to find out if this fits or not. Before I buy one I got a couple sellers that I could choose from? Are you possitive?
Thanks. Tony.
Old Dec 11, 2009 | 07:32 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I bet you could swap in a T5 with that shifter plate and it wouldn't hit.
Sorry, I couldn't resist.
Actually I'm not sure if it would hit or not. Best way to find out is to take the plunge and try it out. If it doesn't quite work you can probably unbolt the shifter from the floor and move it forward a little bit.
Old Dec 12, 2009 | 02:30 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
I see the idea here of wanting your auto to look like a stick when others happen to look in and see it, but what about your shifter handle with that big handle with the push button on the side to be able to shift, arent there gunna be people thats gunna see that and wonder why he wanted it to look like a stick? although maybe you have an aftermarket shifter so I can be wrong, just looking at the posible things many people will see and notice about the idea.
Old Dec 12, 2009 | 08:47 AM
Engine: 3.0L 2JZGE
Your are right I was looking for the 82-84 or so style ball shifter but I found out that there different clips so I would need to swap out the hole assembly for the shifter. But last sunday my neighbor gaved me her old b & m mega shifter she told me that she didnt like it cause it was to hard to pull the trigger but her husband didnt had no problem. I told her it all depends if you take your time in installing it and follow the instructions it should work perfect. So she ended up buying my fav . . . the Hurst Dual Gate Shifter 2, damm. I told her let me get that one of you shes all noo that baby is staying in my car, lol. Anyways well I got the b & m shifter now so im planning on purchasing the ball type that goes with it in white, yup. I just dont like the way it looks like the rubber booth that the mega shifter comes with so yeah.
Tony.
Old Dec 12, 2009 | 08:49 AM
Engine: 3.0L 2JZGE
Funny guy, lol. Yeah a T5 would be fun but not for me I guess. Yeah I know a guy thats selling me one in really good condition for 25. I have a friend that has a T5 so im gonna ask him if I could borrow the plate to try it on my car. And is it possible to move the shifter forward? Wouldnt that screw **** up?
Thanks. Tony.
Old Dec 12, 2009 | 09:31 AM
Engine: that I like
The shifter would likely need relocated to the left also, otherwise it would be way to the right in the boot. Here's the shift plate that I cut for use with a t56, and one with a stock opening. I also cut the opening a little further to the left to provide shifter clearance.
A stock manual shift plate has an opening that is wider, MUCH shorter, and moved up a little closer to the ash tray.
Old Dec 12, 2009 | 09:33 AM
Engine: that I like
Also, if your going for the manual look, you will need a dummy clutch pedal
Old Dec 12, 2009 | 10:21 AM
Engine: 3.0L 2JZGE
Ha Ha HA, Now that would be great. lol. Never thought about that one.
Tony.
Old Dec 12, 2009 | 10:22 AM
Engine: 3.0L 2JZGE
Is there pic here cause I dont know if there is cause here at work sometimes I can not view the pics. ;(
Tony.
Old Dec 12, 2009 | 10:34 AM
Stephen's Avatar
Car: 87 GTA
I see the idea here of wanting your auto to look like a stick when others happen to look in and see it, but what about your shifter handle with that big handle with the push button on the side to be able to shift, arent there gunna be people thats gunna see that and wonder why he wanted it to look like a stick?.......
Just tell lookers that it is the NOS button!
Old Dec 12, 2009 | 10:46 AM
Engine: that I like
Tony.
Can't speak for others, but I see it.
Old Dec 12, 2009 | 02:02 PM
Engine: 3.0L 2JZGE
Take it out and paint it red, my little secret button.
Tony.
Old Dec 12, 2009 | 02:03 PM
Engine: 3.0L 2JZGE
Ok I guess i'll see it when I get home freaking internet blocker thing here at work.
Tony.
Old Dec 12, 2009 | 10:42 PM
Engine: 3.0L 2JZGE
Finally today I got a T5 shifter plate ill try to install it tomorrow and take some pics of it to.
Tony.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
