T-top Headliner Removal
Old Dec 11, 2009 | 12:47 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello All.
I've spent about 2 years of reading these boards (almost all of the threads) and I have really enjoyed the experience, so I decided to join up. I stumbled upon this site doing some searching for 3rd gen Camaro info etc. Now to the point, as the thread title says, I'm looking for some info on the removal of the T-top headliner on my kids 1987 Camaro Z-28. He has a problem with the drivers side seat belt retractor, not retracting, and I want to be able to at least try to fix it, before searching for another one. I tried the search feature, but didn't get exactly the results I was looking for. Anyone got any pictures to go along with detailed instructions?
Old Dec 12, 2009 | 02:55 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
Re: T-top Headliner Removal
try looking up the posts for the abs t-top headliner I know I saw a quite detailed install for that, which would also detail the best way to remove the one you have, I know it was a step by step tutorial. Hope this helps out
Old Dec 12, 2009 | 07:29 AM
onesmartidiot's Avatar
Car: 85 marrow z28, 88 thunderbird 5.0
Engine: 305 4bbl, 302 cobra efi
Transmission: 700r4, aod
Axle/Gears: the crappy one
Originally Posted by 87IROC-DAN61
Hello All.
look into recall information for these cars, im pretty sure ive read many years were recalled. then you can just have chevy do the work and for free
Old Dec 12, 2009 | 10:36 AM
Apparently the retractor recall is not for 1987, but I'll research it some more, you never know, there might be a way to sneak it in, but then there is still the dreaded "sorry, but that part is discontinued/no longer available" reply at the stealership parts counter.
Thanks!!
Old Dec 12, 2009 | 11:16 AM
Thanks Stormr!!! It seems that when I searched before for this, I didn't get the full results, or something like that. I just found what I was looking for searching again, maybe I used the wrong key word? Anyways, I found it!!!
Thanks again!!
Old Dec 14, 2009 | 10:05 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got a complete step-by-step tech article for headliner removal/installation on my website:
http://www.iroczone.com/2009/10/inst...irdgen-f-body/
Hope it helps.
--Jim
Old Aug 11, 2011 | 09:45 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Hi Jim,
The link doesn't work any longer. I hope to install my t-top headliner tomorrow and I'd be interested in seeing your article, whether in a new link or posted here.
Old Aug 18, 2011 | 08:26 AM
82tarecaro's Avatar
It worked for me.
Old Aug 18, 2011 | 09:40 AM
majobis's Avatar
Axle/Gears: G92
I got the link to open and thank you Jim for the article. I was making great progress yesterday until I got to the sunvisors. 30 minutes later and I gave up. I look forward to using your trick to seperate the visors from the mount and installing the mounts first.
morrow
Jan 13, 2024 12:29 PM
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
