how to remove back seats?
Old Dec 14, 2009 | 02:38 PM
TheREVOLUTION22's Avatar
Car: '84 Z28, '06 Scion tC
Transmission: auto
how do i remove my back seats in my camaro?
i cant seem to find the bolts that need to come out....
Old Dec 14, 2009 | 02:51 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: how to remove back seats?
Under the front edge of the seat, there is a 12mm bolt you remove, this will free the seat cushion. After removing the seat cushion, the bottom outside corner of each backrest has a 12mm nut which will unfasten the hinge. Then the seats will come out.
12mm might be 13, but 12mm comes to mind.
Old Dec 14, 2009 | 02:56 PM
Transmission: auto
oh lol i stuck my finger in there. i figured he bolt woulda been down on the floor i just had to feel upwards haha.
wow i found a dead mouse in there! ah!
thanks man
Old Dec 21, 2009 | 05:37 AM
Sharronholloran's Avatar
There are 2 basic ways to remove back seats. Remove bolts below the bottom cushion. If no bolts, It comes out by either pulling up or pushing straight back then pulling up. The back section is usually bolted at the bottom. Unbolt and tilt lower end foreward. Push up and press in on upper middle of the back to clear 3 hooks on upper back. Hope this helps.
_____________
Contract Hire | Car Breakdown Cover
Old Dec 21, 2009 | 02:27 PM
Transmission: auto
i got em out thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
