need help with dash
need help with dash
have a 86 camaro the dash is crscked tryed to take dash out try and fix it have taken the dash pad off have all top dash screws and bottom dash screws out got top ac pipeing out of the way got top anchor nuts off and bottom bolts off the passenger side will come out find but the driver side is not moveing as there any think i have missed do i need to unbolt the sterring colnum please help
and ps yes i know i am a bad speller
Re: need help with dash
The steel support bar in the dash is bolted to the same bolts that support the column... You'll need to at least drop the column to get the dash out.
