Interior lights/Horn/cigarette lighter stopped working
Old Jan 17, 2010 | 05:58 AM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
I did a search and believe it could be an "ACC" fuse...however, I opened up the fuse panel under the drivers side dash, and there are no labels or anything...Could someone tell me which fuse it is
Thank you!
Old Jan 17, 2010 | 06:01 AM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Re: Interior lights/Horn/cigarette lighter stopped working
Hm on second thought, I just read some thread that it should be labelled near the fuse...I'll go down later and see if "ACC" is labelled.
Old Jan 17, 2010 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check post #1 one of the following link for a pic/diagram:
https://www.thirdgen.org/forums/elec...ml#post4350355
JamesC
Old Jan 17, 2010 | 08:18 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
its the number 20 fuse under the fuse panel... i think there are like 3 or 4 number 20 fuses.. just take each one out and look at which one is burnt out... replace that one with another 20 fuse and it will come back on... it should be on the bottom left hand side... that fuse bascially controls all the power functions inside including the ones your talking about...
Old Jan 17, 2010 | 08:28 AM
JamesC's Avatar
The link above "should" eliminate searching for a blown fuse.
JamesC
Old Jan 17, 2010 | 08:31 AM
88fastgta's Avatar
i know i just replace my blown fuse with them exact same problem less than two weeks ago..... we both have firebirds..... i know its a orange #20 fuse i just dont remember where exactly it is because there are 3 or 4 other #20 fuses down there....
Old Jan 17, 2010 | 10:31 AM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
thanks both of you ^^ Very helpful.
Going out to get my new fuse now
Old Jan 17, 2010 | 11:55 AM
thecraze's Avatar
When I bought my Camaro, the horn/lights/lighter weren't working either. Hopefully it was an old fuse for you, because I had to replace the horn and lighter for the fuse to stop frying.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
