Custom dash question
Old Jan 17, 2010 | 06:22 PM
bcfipp's Avatar
I have a template made for my dash. I am going to order the gauges soon. what is the best material to use. Maybe a sheet metal or and type of board. Or would it be easier to use the plastic clear piece and fiber glass it a little to make it even. Any help would be great.
Old Jan 20, 2010 | 10:43 AM
aarivers's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: T-5 Manual
Axle/Gears: 3.42 4th Gen
Re: Custom dash question
When say "dash" are you talking about the entire dashboard assembly, or are you just talking about the gauge cluster, and removing it and placing a blank panel in there to install your custom gauges into?
Old Jan 20, 2010 | 03:23 PM
bcfipp's Avatar
The gauge cluster part. I would like to put aftermarket gauges.
Old Jan 22, 2010 | 10:36 AM
aarivers's Avatar
Engine: 305 TBI
Well then I would say whatever material you can get a hold of and will be easiest for you to work with. ABS plastic would be the easiest and cheapest if I had to guess, next would be wood, then finally metal.
I like the idea of putting the clear factory gauges plastic panel in front of the aftermarket gauges installed into an ABS board.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
