LED Dash lights
Old Apr 11, 2010 | 11:39 AM
  #101
Camarokid86's Avatar
Re: LED Dash lights
hey i was curious if they sell the same thing but in like a bright green? and how much did you pay for those? thanks!
chase.
Old Apr 11, 2010 | 12:30 PM
  #102
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: LED Dash lights
Originally Posted by Fyrstorm
Should nickname your car Stormtrooper
explain pls ?
dont get it
Old Apr 18, 2010 | 09:13 PM
  #103
spoolingturbo6's Avatar
Re: LED Dash lights
1992 Camaro, T10 - 194 L.E.D.'s Size:: 22mm x 11mm
Qty 10 $5.00 built in resistor.
Got them off Ebay CHEAP from this seller
LINK
I took a screwdriver and pushed out the old lamp from the socket.
Then removed the remaining wire with a small straight screwdriver.
Pointed the leads straight out, and put the L.E.D. into the stock socket.
Next Folded the leads down onto the stock holder, And soldered them into place.
Getting the polarity figured out was fairly simple, ( small lead is the + side )
If you install them backwards, They will not emit light, (Simply remove and turn 90*)
Leave dash loose till you verify all are on, and turn the ones that don't.
Tyson R.
Attached Thumbnails LED Dash lights-27260_119376408079005_100000199406314_301117_4467759_n.jpg   LED Dash lights-27260_119376561412323_100000199406314_301123_4314150_n.jpg   LED Dash lights-27260_119377894745523_100000199406314_301128_7733005_n.jpg
Old Apr 18, 2010 | 10:41 PM
  #104
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
Re: LED Dash lights
LINK
Tyson R.
thats where im at with half my lights out...
Old Apr 18, 2010 | 10:47 PM
  #105
Chezoom's Avatar
Engine: LO3, LG4
Re: LED Dash lights
has anyone done it in a 90-92 camaro yet???
Old Apr 19, 2010 | 02:49 AM
  #106
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: LED Dash lights
yups I did it.
they only have 4 light bulps to replace, but its the same principle.
( btw, I already said that I did it in a 1991 camaro.
Old Apr 19, 2010 | 10:27 AM
  #107
Chezoom's Avatar
Engine: LO3, LG4
Re: LED Dash lights
pics homes!!!!!!!!!!!!!!!!!!!!
Old Apr 19, 2010 | 10:44 AM
  #108
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: LED Dash lights
readthe topic again, I cant, afterwards I changed the dash for a nordskog digital dash
Old Apr 19, 2010 | 11:18 AM
  #109
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: LED Dash lights
Originally Posted by TheFab
Hey guys!
How many bulbs will I need for a Firebird dash?
I searched for the answer but couldn't find anything.
Thanks in advance.
firebird dash takes 9 bulbs for the backlighting
Old Apr 22, 2010 | 08:26 PM
  #110
TheFab's Avatar
Car: '89 Firebird
Engine: 2.8l MPFI
Transmission: Automatic
Re: LED Dash lights
Thank you for replying!
I have already looked for myself, though. Also, I did install bright white LEDs. Originally I was planning on doing a nice red color by installing some kind of film but when I looked at the pure white, I got hooked.
I love how the different colors stand out. I mean with the stock orange you can't really tell they're there.
I only got a picture of when I was in the middle of installing them. Some didn't light up on first try, so there are some dark areas.
(also, they appear a lot brighter if seen in person)
Old Apr 23, 2010 | 01:26 PM
  #111
regal301's Avatar
Car: 1988 iroc-z
Re: LED Dash lights
looks good.
the stock bulbs suck.
i swapped mine for red 194's ,cost me $10. i was worried about the light pattern of the led's
Old Apr 24, 2010 | 03:06 PM
  #112
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Re: LED Dash lights
Originally Posted by Timmie
explain pls ?
dont get it
Hmm! I went back and I didn't see any interior pics anymore in the thread - maybe I was looking at your garage. Looks almost white and black in there, like a stormtrooper from Star Wars hehe!
Old Apr 25, 2010 | 07:23 AM
  #113
Camaros4Life's Avatar
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
Re: LED Dash lights
Are the bulbs from the earlier years the same as the ones for 91-92?
Old Apr 25, 2010 | 07:50 AM
  #114
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: LED Dash lights
@Fyrstorm aa yes, that way.
yups, the details like door handles , shifter , E-brake, and some buttons are still in black
@camaros4life, yes the bulbs are the same
Old May 5, 2010 | 01:45 PM
  #115
Re: LED Dash lights
Did You just see my Post Above. YES
Old May 7, 2010 | 08:09 AM
  #116
Car: 84 Camaro
Re: LED Dash lights
ok i just got my led lights. they are yellow 194's. Ok so i installed them last night and went out for a drive, i can barely see the gauges. Now i have read to either paint the back white gloss/ metallic or put aluminum foil over the back of the metal faceplate that goes over the gauges.
how do you secure the aluminum foil? or is it easier to just spray paint it? also, my dimmer switch will not dim anything. it will either go all the way on, or completely off. I just replaced it because my old one was doing the same thing. Any ways to fix this?
I would really appreciate help with this because it was very discouraging last night when i turned the lights on and it barely lit the dash up.
thanks
scott
Old May 8, 2010 | 09:35 PM
  #117
mrr_mobile's Avatar
Re: LED Dash lights
Originally Posted by Rockyd
hey 92 you should look at my gauges for the 91 92 camaros layovers and really easy to install look at my cardomain in my sig
I really like the instrument cluster... How did you get that effect?
Old May 8, 2010 | 09:43 PM
  #118
mrr_mobile's Avatar
Re: LED Dash lights
Originally Posted by Al Hasse
I've got an updated picture of mine. Not a whole lot of difference, maybe a bit truer red now that I've painted the back of the metal bezel a flat white. I've also painted the front of the bezel red to match the car.
Pay no attention to the dirty interior (work in progress )
And the lighted gauges...
That looks awesome! I wonder what the blue version of that looks like?
Old May 11, 2010 | 10:57 PM
  #119
BoomBoxx's Avatar
Car: Purple & Black 1984 Trans Am T-Top
Re: LED Dash lights
Swweeet, I F-ing love this thread. Can't wait until I'm ready to do a mod of my own.
Old May 11, 2010 | 11:06 PM
  #120
C_Sander's Avatar
Car: 91 Camaro RS
Engine: Carbureted 305
Re: LED Dash lights
Wow I reay started something here... I had no idea this topic would be so popular
Old May 11, 2010 | 11:40 PM
  #121
aviator84's Avatar
Re: LED Dash lights
Originally Posted by Camaros4Life
...my dimmer switch will not dim anything. it will either go all the way on, or completely off. I just replaced it because my old one was doing the same thing. Any ways to fix this?
The stock dimmer switch will not dim led bulbs.
edit: You will need a pulsewith dimmer to dim led bulbs.
Old May 12, 2010 | 11:09 AM
  #122
TheFab's Avatar
Car: '89 Firebird
Engine: 2.8l MPFI
Re: LED Dash lights
Not really true.
The bulbs posted by spoolingturbo6 (assuming, they are the same as mine. Mine are from a different brand but they look absolutely identical) do work with the dimmer.
I have them, installed them and the dimmer works just like it does with regular bulbs.
Old May 12, 2010 | 11:14 AM
  #123
BoomBoxx's Avatar
Re: LED Dash lights
Not really true.
What brand did you buy? Where from please?!
Old May 12, 2010 | 11:42 AM
  #124
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: LED Dash lights
just ordered 12 from brightleds.com(orwhatever) for my T/A
will post pics when installed..
Old May 12, 2010 | 01:07 PM
  #125
TheFab's Avatar
Car: '89 Firebird
Engine: 2.8l MPFI
Re: LED Dash lights
I bought them in one of their shops: http://www.atu.de/pages/shop/home.html
Unfortunately, I couldn't find them on their website. I'm sure they don't produce the bulbs themselves but they sell it under the ATU brand. I still have the box they came in. I'll see if it says something about who produces the bulbs.
If it doesn't I could ask directly. You should know that they're pretty expensive. It's about 12€ (about $15) for two bulbs. As my Firebird needs 9 bulbs for the gauges I had one to spare which I used to replace the one that lights the license plate. (love that look)
Old May 12, 2010 | 01:26 PM
  #126
BoomBoxx's Avatar
Re: LED Dash lights
Yikes 12 euro? I might have to wait, or just forgo the dimmer idea. I think I'll need 9 too for the gauges as I have the stock 84 dash. Maybe I'll do the blacklight in the dash...oooooh! LOL
Which did you put in the dash, 1 diode or 4 diode leds?
Old May 12, 2010 | 02:19 PM
  #127
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: LED Dash lights
I put LED bulbs in my cluster a few months ago and they all went out on me.
First they started to flash on and off on the oil press side and worked its way towards the speedo, eventually all of them going out or just flashing.
They looked great when they worked, just like TheFabs's car.
I must have gotten a bad batch or they didn't like the heat cycling since I had them in there over the winter and it got pretty cold here.
Old May 12, 2010 | 02:52 PM
  #128
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: LED Dash lights
that sucks what brand were they??
Old May 12, 2010 | 05:39 PM
  #129
Zepher's Avatar
Re: LED Dash lights
They were cheap ones I got from a vendor on ebay.
Old May 12, 2010 | 06:13 PM
  #130
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: LED Dash lights
whos the ebay vendor that you used
try Vleds
Old May 12, 2010 | 10:42 PM
  #131
aviator84's Avatar
Re: LED Dash lights
Not really true.
Thanks for clearing that up. I didn't realize some of the bulbs would work with the stock dimmer.
Old May 14, 2010 | 01:57 AM
  #132
bluegizmo1983's Avatar
Re: LED Dash lights
So I just finished this LED Dash light mod in my 91 Camaro, thought I'd share my findings..
Firstly, I am unhappy with the results and will be redoing it again in the future. I used Blue 194 mini wedge bulbs from Superbrightleds.com (WLED-B4-32). The bulbs themselves are great, I just chose the wrong ones I guess.
My gauge cluster (assuming all 90-92 will be the same) only takes 4 bulbs to light all the gauges. I purchased the 30 degree bulbs (angle of light) which was a BAD choice... DEFINITELY go with the 90 degree bulbs if you are doing this mod. With the bulbs I purchased, the needles are really bright, but the digits on the gauges and the rest of the gauge in general and super dim and barely readable at night.
I should also note that I did not modify my cluster in any way. I did not paint or foil the inside of the cluster, it still has the stock gauge overlays, everything is completely stock except the 4 Blue LED bulbs to light the cluster.
Old May 14, 2010 | 03:05 AM
  #133
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: LED Dash lights
I guess you could always try painting/foil and see what your results are before doing anything else? Give it a shot and see if that helps.. then again - if you're tearing things apart, maybe you should just try a different bulb AND paint/foil while you've got everything out again.
Old May 14, 2010 | 03:11 AM
  #134
Re: LED Dash lights
Yeah I think thats what I'm going to do... I just placed another order with superbrightleds.com... This time I ordered 4 of the twist in sockets for the bulbs so I don't have to mod the original sockets again!
I also ordered 4 of the 5xLED bulbs with a 220 degree angle to see how those work, as well as 4 of the same bulbs I originally order but in 90 degree this time.
When I do the foil/painting, where and what exactly should I be foiling? Does anyone have some pictures? I'm assuming I just foil the entire inside of the cluster behind the gauges, basically where the bulbs will sit and emit light.
Old May 14, 2010 | 10:44 AM
  #135
BoomBoxx's Avatar
Re: LED Dash lights
I am looking to install LEDs in my 84 TA 3rd Gen dash. I am counting 9 that I need (not including turn signals and brights). The back of my gauge housing is white, but kind of dingy so I'll probably paint it white. Also, the back of my bezel has been spray painted orange (I think by the factory) just like under the P N R O D 2 3 indicator. So both of those reflect orange. I tried covering the orange with foil pretty quickly and didn't cover all areas 100%. This really improved the brightness of the gauges at night although they did still have a slight orange glow. I would suggest the spray paint unless you do a really detailed job with the foil. My plan is the fill the gauges with purple (UV blacklight) LEDs to replace the stock. Does anyone have any advice on if this will work well or not? The UV is the dimmest of all the LED colors so I was planning on using all 4X LEDs. I figured that would blast enough light out no matter what color, but wanted to see if anyone had any advice on whether or not it will be enough. Anyone have any experience with these bulbs?!
Update: I am also just realizing that the back of the actual gauges are fluoro orange too! I'm suspecting that these need to be painted or covered as well in order to eliminate the orange completely as orange +purple = ugly brown. Anyone have any words of wisdom on this? Good idea? Bad idea?!
Old May 14, 2010 | 04:27 PM
  #136
BoomBoxx's Avatar
Re: LED Dash lights
Which bulbs did you buy? How many diodes per LED? I doubt 1 will do it especially if you only have 4 sockets in the dash. I am going with 4 diodes per bulb and 9 bulbs so hopefully that will be bright enough! I'd say don't bother with single diod LEDs...
Old May 14, 2010 | 05:31 PM
  #137
C_Sander's Avatar
Car: 91 Camaro RS
Re: LED Dash lights
Like i said in post #11, you need to use 90 degrees to get a good spread, and always use 4 or more diodes. One diode is NOT enough. Especially in your case, where you only had 4 sockets.
Old May 14, 2010 | 09:38 PM
  #138
Re: LED Dash lights
How do I tell how many diodes there are?? These are the bulbs I purchased http://www.superbrightleds.com/cgi-b...%2FWLED-x4.htm
Old May 14, 2010 | 10:14 PM
  #139
BoomBoxx's Avatar
Re: LED Dash lights
If you look at the diagram, you will see the 4 mini LED bulbs (Diodes) sticking out of the top. If those are the ones you bought (WLED-4X) then you bought the ones with 4, not 1.
Old May 17, 2010 | 08:48 PM
  #140
Re: LED Dash lights
Hey guys, a few more quick questions...
Do the gauges in a '91 have any sort of light filter that needs to be removed when changing to a colored LED bulb?
Also, I purchased 4 of these twist in sockets, T10S-TW, from superbrightleds.com to install my bulbs this time. Anyone ever used these sockets? Do they fit right into the cluster?
Old May 18, 2010 | 04:02 AM
  #141
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: LED Dash lights
those are the ones that are standard in the back of your cluster.
and to be honest I dont get why you bought them.
you just had to take out that socked, take the bulb out of the socket, and put the new led bulb into the socket.
Old May 18, 2010 | 05:36 PM
  #142
Re: LED Dash lights
Maybe my bulbs are aftermarket or something then because the sockets that are in my cluster are a little bit different... They do not have the proper contact points for the bulbs.
When I replaced my bulbs the first time, I had to break the contact wires on the original bulbs in the sockets because they were soldiered to the contact points on the sockets, and when I inserted the bulbs from superbrightleds (mini wedge 194 bulbs) the wires on the bulbs did not touch the contacts on the sockets, so I had to bend the wires on the bulbs and then soldier them to the contacts on the socket...
I'm going to take extensive pictures when I swap the bulbs again in a few days. I'll post them when I've finished.
Old May 23, 2010 | 05:11 AM
  #143
Firebirdstu's Avatar
Car: 82 Firebird
Engine: 5.7 400hp Gto 350 block
Transmission: th350
Re: LED Dash lights
I just totally did away with my clocks and went for all led's
Old May 23, 2010 | 05:38 AM
  #144
KITT1983's Avatar
Re: LED Dash lights
now thats a awesoem dash
Old May 24, 2010 | 12:26 PM
  #145
KN1GHT's Avatar
Car: 1989 TA
Engine: 350tpi
Axle/Gears: 3.73 posi
Re: LED Dash lights
Originally Posted by KITT1983
where can i get these gauges
go to mark's custome kits.....$1500 for digital guages for our car.
http://www.markscustomkits.com/Interior-Products.htm
Old May 24, 2010 | 04:10 PM
  #146
KITT1983's Avatar
Re: LED Dash lights
thanks for the llink mike
Old May 26, 2010 | 08:21 AM
  #147
Car: 82 Firebird
Transmission: th350
Re: LED Dash lights
My set are from www.jupitere.com
theres also www.knight-f2k4.com that also supply 3/4 dash electrics
Old May 26, 2010 | 01:25 PM
  #148
BoomBoxx's Avatar
Re: LED Dash lights
Haha...that's what I paid for the whole car!
Old Jun 12, 2010 | 02:42 AM
  #149
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: LED Dash lights
Old Jun 18, 2010 | 01:49 PM
  #150
Abandon's Avatar
Re: LED Dash lights
This is an awesome thread. Replacing all the interior lighting will probably be one of the first interior mods I do.
