tilt column compatability
Old Feb 1, 2010 | 10:13 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
my tilt column took a crap is it possible to use a non tilt column from one of
the earlier third gen camaros and swap em out ?
Old Feb 2, 2010 | 10:59 AM
eschevyrda's Avatar
Car: 89camaro rs
Re: tilt column compatability
BUMP
Old Feb 2, 2010 | 04:01 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Your profile shows you have an '89 Camaro. If that's the case, you actually need to use a column from an '89 to keep everything working correctly. The only difference between 84-88 and 89 columns is the VATS system so if you bypass the VATS system you can use an 84-88 column.
Old Mar 27, 2014 | 02:39 PM
crashcrtr's Avatar
Car: 1992 Chevy Camaro z28
Anybody know the compatibility for a 92 steering column?
Old Mar 27, 2014 | 05:36 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
90-92,........
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
383cam
Sep 9, 2015 06:01 AM
Ian Irvine
Sep 4, 2015 08:08 AM
