what to use for insulation?
Old Feb 19, 2010 | 05:33 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
ive been searching for a good stick on insulation to do my firewall and floor pans with. im not so much worried about sound deadening i just remember when i had this car on the road alot of heat came through the firewall and pass side floor pan and i want to stop that so the car is more comfortable to drive in the summer. so of all the stuff out there what offers the best insulation and wont break the bank?
Old Feb 20, 2010 | 01:57 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: what to use for insulation?
I use the stuff laid under household carpeting... Dirt cheap. I could do my whole car for roughly $50, and have leftovers. I'd just make sure to get the stuff that has the blue plastic like stuff on top that helps keep the water away from the floor pans (it's used in bathrooms and other wet places). It's not stick-on, though. You'd need a can of spray adhesive like GM used.
Old Feb 20, 2010 | 11:54 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
http://www.secondskinaudio.com/ Works great, costs less than dynamat, and isn't asphalt based.
Old Feb 22, 2010 | 09:03 AM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Did you get just the Damplifier, or did you also add the Overkill or Luxury Liner too?
Old Feb 24, 2010 | 10:51 AM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
I personally used their Spectrum product for vibration dampening and the Luxury Liner for sound blocking. Spectrum is more effective then the Damplifier but they are comparable nad Damplifier can easier to install.
Worked fantastic.
gta_knight
Sep 23, 2015 04:59 PM
Bob63
Mar 14, 2002 09:43 PM
89 Iroc Z
Sep 6, 2001 08:07 PM
rudys119
Aug 5, 2001 06:27 PM
FLYINHY
Mar 15, 2001 12:31 PM
