Tach replacement
Old Feb 21, 2010 | 12:11 AM
f-bodymikey's Avatar
Car: 84 Z-28
Engine: 355 4 bolt main
Transmission: 700 R4
Axle/Gears: Posi 3.73
Tach replacement
Can I replace my V8 tachometer with and another V8 tachometer without having to replace the whole gauge cluster?
Old Feb 21, 2010 | 01:01 AM
osso12's Avatar
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
Re: Tach replacement
Yes.
Old Feb 21, 2010 | 02:36 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
First off what's wrong with the one you have now? You may only need to change the board and not the entire tach.
Old Feb 21, 2010 | 07:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the gauge is faulty, you can replace it from the front (no cluster removal). Gauges are pretty much plug and play. Twenty minute job.
JamesC
Old Feb 21, 2010 | 08:17 AM
Car: 84 Z-28
Just recently my tach has been erratic first start up of the day. It either stays at zero or bounces all over the place. Than after about 10 to 15 minutes of driving it catches where it should be and reads right again. Someone told me to try to direct wire past the tach filter to see if thats the problem, but some one cut both wires going from my tach filter. So in short it isn't hooked up anyway. I have owned my camaro for 4 years and this is the first time this has happened. Thanks for the help.
Old Feb 21, 2010 | 11:04 AM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Seems to be a common problem as these cars get older.
Heres my thread on pretty much same subject. On mine I might end up having to replace the cluster to resolve the issue:
https://www.thirdgen.org/forums/elec...r-problem.html
Old Feb 21, 2010 | 11:18 AM
Drew's Avatar
82-89 Camaro; Yes... But at least the 85-92 Firebirds the gauge cluster has to come out and screws removed from the back to remove the gauges. I want to say the 90-92 Camaro is the same way. I've never had a 82-84 Firebird cluster apart, so no help there.
Old Feb 21, 2010 | 11:31 AM
JamesC's Avatar
Thanks for the clarification. I was addressing the issue with his 84 Camaro.
JamesC
Old Feb 21, 2010 | 11:36 AM
Drew's Avatar
LOL I'd swear when I replied there was no year/model listed... I did look before I replied.
Old Feb 21, 2010 | 11:41 AM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Agreed... I just assumed it was an 84 Z-28 as that is what is in his profile.
Old Feb 21, 2010 | 11:45 AM
Drew's Avatar
Except when I replied, that info wasn't in his profile.
Old Feb 21, 2010 | 12:02 PM
JamesC's Avatar
Drew, old fellow, only take the meds in the correct dosage and at the correct time.
JamesC
Old Feb 21, 2010 | 12:04 PM
Car: 84 Z-28
Sorry guys. Yes my car is one of the 100 thousand Z-28 Camaro's built in 1984. Thanks for the help though.
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
