85 to 140 cluster swap
Old Feb 22, 2010 | 07:27 AM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
i have an 85 t/a with the 85mph cluster, and i have a used 140mph cluster on the way, not sure what its out of but i think its an 85 too. what is involved in swapping the 85 to the 140?
thanks
Old Feb 22, 2010 | 07:51 AM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: 85 to 140 cluster swap
is your 85 cluster cable operated.replacing the cluster is easy but take your time and dont just try to pull it straight out, you have to tilt it out
Old Feb 22, 2010 | 11:14 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Your '85 Trans Am has a cable driven speedometer. All of the 120 and 140 MPH Firebird speedometers are electronic so you'll have to convert your car over for an electronic speedo. (All '86-'92 Firebirds got electronic speedos.) There are posts here on TGO that tell you everything you need to do.
Eric2ndGen
Nov 5, 2015 01:51 PM
Bstrang6
Sep 8, 2015 04:29 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
