c&c t-top headliner Questions
Car: 91 Camaro Z28
91 camaro with c&c tops and im doing the headliner
in abs what do i need to do i have read all over the site and nothing really goes into detail. my headliner is coming apart fiberglass showing
could i fiberglass the side that shows?
if i get abs one how to cut and when i intall what about wraping material around t-top opening
i just need some input thanks
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: c&c t-top headliner Questions
i didnt know my car had c&c t-tops till i bought aftermarket abs headliner.
basically the CC headliner is flat and the gm style isnt.
on a aftermarket headliner you gota use a dremel or straight metal cutter and cut off the walls of the headliner
then u need to have it re-wrapped.
u could fiberglass you original headliner then re-wrap it.
have fun. just gota keep cutting and keep test fitting
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I used a hardtop headliner to replace my original C&C piece.I installed it in one piece, then trimmed it to fit around the C&C t-tops.Much easier than trying to fit/trim an ABS unit....
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The Headliner in a C&C car was oringally a Factory GM Hardtop headliner that C&C modified to fit during thier conversion.
ambainb
Apr 25, 2016 09:21 PM
1986, aftermarket, berlinetta, camaro, cars, cc, headliner, headliners, parts, repair, top, tops, trans, ttop, ttops
