Hole under the spare tire?
Old Mar 5, 2010 | 05:18 PM
THEGunboundGod's Avatar
Car: 1986 Z28
Axle/Gears: 4.11
I found this when I moved the spare tire. Is that suppose to be there?
Old Mar 5, 2010 | 05:38 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: Hole under the spare tire?
Normal but I believe a plug is normally in there.
Old Mar 5, 2010 | 05:40 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
yes it's supposed to be there . not sure of the purpose , you should have a rubber plug to cover it . good luck .
Old Mar 5, 2010 | 05:56 PM
Car: 1986 Z28
Axle/Gears: 4.11
Does anyone know a site that sells one?
Old Mar 5, 2010 | 06:26 PM
Camaros4Life's Avatar
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
unfortunately i dont think anyone sells that one plug, i was missing mine too. PO are retarded most of the time and remove stuff and do not put them back. I took some silicone and just put some over the hole until i found a rubber stop that i modified from a hardware store to cover the hole.
Just put a little silicone over it if you are worried until you find something to plug it with
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
fasteddi
Sep 10, 2015 09:32 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
