4th gen radio in a 3rd gen
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: T-5 Manual
Axle/Gears: 3.42 4th Gen
Re: 4th gen radio in a 3rd gen
Judging by your other posts this is for your 87 GTA. If so, you should not have to change anything besides maybe an antenna adapter. The radio harness should be the same for the late model radio as the harness in your car. Just plug and play.
yeah they wires arent the same in my factory harness , i have only 6 wires from my harness which im going to cut off those connectors and im goin to splice on to the harness i got from the 4th gen radio it has about 12 - 15 wires
Engine: 305 TBI
http://www.installer.com/item/displa...php?it=71-1858
Car: 89 Iroc Convertible
They make an adaptor harness you can use instead of cutting your wires.The 3 big plugs go in one end and the other end has a 21 pin plug which is what the newer radios use.You will alos need an antenna adaptor as the newer radios have a smaller antenna plug.I had to do this in my 86 iroc when I installed a mid 90`s delco cd player
