t-top liner install question
Car: 1988 Camaro IROC Z
Engine: 5.7L TPI
what is the trick to threading the seatbelt in hole provided? do I need to make a cut to slide the belt through?
Car: 1985 Z28
Engine: 305 LG4
Re: t-top liner install question
Yes, make a cut from the center of the hole straight out to the outer edge of the liner. You should have some plastic covers attached to your seatbelt that slide up and snap in, covering the slit. Maybe someone can attach some pictures of it for you so you get it right.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Here's a pic of those covers that slide up and click into the retractor assembly in the roof:
http://cgi.ebay.com/ebaymotors/85-87...Q5fAccessories
84z96L31vortec
Aug 20, 2017 12:16 AM
