84 z28 speedo....
Old Mar 25, 2010 | 05:36 PM
PT3BOOMER's Avatar
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
84 z28 speedo....
Anybody know where I can get an 84 speedo Without the kilometers....because I know I'm going faster than 85mph....
Old Mar 25, 2010 | 05:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 84 z28 speedo....
Why not swap in a 115 or 145?
JamesC
Old Mar 25, 2010 | 06:00 PM
PT3BOOMER's Avatar
Axle/Gears: STOCK
How do I do that or where? Is it year specific for the car?
Old Mar 25, 2010 | 06:03 PM
PT3BOOMER's Avatar
Axle/Gears: STOCK
Ok I Meant I need a speedo with more than 85mph on it without the kilometers for an 1984 z28
JamesC's Avatar
As long as the speedo is cable driven (82-89), you can swap the speedo head of your choice in. You'll have to pull the cluster, which is a half an hour job. Check the first link in the following link:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Mar 25, 2010 | 06:11 PM
PT3BOOMER's Avatar
Axle/Gears: STOCK
It can't go over 85mph because the kmh side needle pegs against the trip reset button
Old Mar 25, 2010 | 06:23 PM
JamesC's Avatar
As long as the speedo is cable driven (82-89), you can swap in the speedo head of your choice. You'll have to pull the cluster, which is a half an hour's job. Check the first link in the following link:
JamesC
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
