Gas Gauge
Old Mar 26, 2010 | 08:22 PM
83ta5speed's Avatar
Gas Gauge
hey guys i have an 83 ta and my gas gauge doesnt work its stuck up past full... ive found 2 wires that are unplugged that come off the gas tank on the drivers side they exit just above the drivers side exhaust pipe there is a pink wire and a black one they are on the same connector this wire is only 7-8 inches . i just cant seem to find the other side of the connector that plugs into this where would it be routed though on the car? ive looked in the jack compartment where the wire harness is for the tail lights, there is a black wire there but its not hooked up and i tested it with a test light and there was no power any info would be appreciated
Old Mar 27, 2010 | 12:08 AM
84 Kamp311's Avatar
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
Re: Gas Gauge
it reads OHMS 0-90 one wire is ground and the other goes to the gauge. im suprised Stephen hasnt told you anything yet LOL
Old Mar 27, 2010 | 04:23 AM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Re: Gas Gauge
^LOL
Old Mar 27, 2010 | 04:00 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Gas Gauge
Those wires follow the taillight harness, and enter the car on the rear drivers side.
Old Mar 27, 2010 | 06:44 PM
83ta5speed's Avatar
Re: Gas Gauge
Ok where the tail light harness is there is only 1 black wire and the pink wire that goes from the sending unit to the gauge has no power neither does the black wire that i found unhooked there. do u know what color the wire is that plugs into the pink one is?
Old Mar 27, 2010 | 07:56 PM
84 Kamp311's Avatar
Engine: 406
Re: Gas Gauge
your looking for a pink wire in the wiring harness
Old Mar 28, 2010 | 09:58 PM
83ta5speed's Avatar
Re: Gas Gauge
The only pink wire that i found was in the taillight harness itself no other pink wire or is that the one that you mean?
Old Mar 29, 2010 | 07:44 AM
84 Kamp311's Avatar
Engine: 406
Re: Gas Gauge
yep its got to be
Ghettobird52
Jul 5, 2024 11:18 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
