Speedo swapped, some questions
Old Apr 1, 2010 | 04:22 PM
willy241's Avatar
Car: 87 Z28
Well i searched and didn't see the answer I was looking for.
I just swapped my 85mph speedo with a 145mph today. I also swapped out the odometer wheel in both since the difference between the two was rather large. I didnt take the needle off, but was able to get the odometer roll in and out. Once I swapped, everything went in great, put that little metal piece back on to hold the roll, and put my dash back together.
My speedo is working fine, but the odometer isnt moving. So is there any possible area I might have screwed up on?
Also, what are the odds I need to recalibrate since getting a new speedo? I feel like it might be off a little.
Other than that, the swap went fine
Old Apr 1, 2010 | 06:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo swapped, some questions
If the "J" clips are broken, the odometer won't function. Check the following link:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
No need to calibrate anything.
JamesC
Old Apr 1, 2010 | 06:42 PM
willy241's Avatar
Car: 87 Z28
i only saw one clip like that and it was on the one side of the roll (the left if you look at it from the front). I put that back in and that secured the roll, but i didnt see a second one. the clip was a brownish color but im sure there was only one
Old Apr 1, 2010 | 08:52 PM
JamesC's Avatar
Not a "J" clip.
JamesC
Old Apr 8, 2010 | 01:27 AM
willy241's Avatar
Car: 87 Z28
Originally Posted by JamesC
Not a "J" clip.
JamesC
yeah realized that. there werent any J clips when i removed the mileage roll. im at school until summer but its the first thing on my list when i get home
Old Apr 11, 2010 | 07:57 AM
alberthugo's Avatar
hi james...................
i try to look up my camaro yesterday,but i got a difficulty to remove the speedometer.....
can you help me out
Old Apr 11, 2010 | 09:07 AM
JamesC's Avatar
can you help me out
Check the link I provide in post #2 for removal.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
