gauges do not work!
Old Apr 10, 2010 | 12:44 PM
mongoosekeith's Avatar
gauges do not work!
I finally got my car running to find none of the gauges work properly, the tachometer reads 7K anytime the motor is runnin, amps does not work, fuel dont work reads full all the time, temp is allways all the way up and this cluster is in an 88 2.8 v6 and it is the 110 speedo any ideas what is makin these things not work?
Keith
Old Apr 10, 2010 | 03:46 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: gauges do not work!
check to see tach hooked to the power side or the tach terminal on the distributor, if you got a coil-in-cap then test the coil for shorts.. Its weird because a lot of the gauges are independent. check maybe the ground shorted. check fuse block for a fuse labeled gauges too. and might even try disconnecting the tach wire off the distributor and probe it for voltage, ground continuity. Next i would disconnect the wire to the temp sender on the block, i think its between drivers side 5th and 7th cylinder sparkplug on the head/block. check the wire for voltage and ground continuity. Does the car run sweet?
Old Apr 10, 2010 | 10:56 PM
well my gauges all come out like plugs on the cluster, but they just dont work properly, the car has been parked since early 04 cause it just crapped out i bought it in 09 and been saving to get a new motor and now the gauges dont work. but the tach aint really all that important since its an auto but i would still like everything to work correctly. and yeah it runs perfect. now the e break is stuck on but i will get it working tommrrow
Ghettobird52
Jul 5, 2024 11:18 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
