Does anybody make the roll up cargo covers?
Old Apr 10, 2010 | 08:24 PM
supercharged024's Avatar
I'm wondering if anybody makes the roll up cargo covers that these cars use to have. My 87 Shelby Charger had the same kind of thing for the hatch area and I need to find someone that sells them, whether it's some kind of universal fit or specific fit thing. Anybody have any ideas?
Old Apr 10, 2010 | 08:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Does anybody make the roll up cargo covers?
I see them on ebay - never seen anyone make one.
Old Apr 10, 2010 | 09:32 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
check some of our sponsers, ebay, craigslist, junkyards even. you can find them but i doubt you can buy them new, hell check on our classified board, you might get lucky.
Old Apr 11, 2010 | 10:02 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
I have a brand new rollout cargo cover black that fits a 1984 iroc. If I remember correctly it would fit in my 1992 also. Send a pm if you want pics or such. I got it with a car that someone was "restoring" and it had a ton of new parts with the car.
Old Apr 13, 2010 | 10:58 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
The roll up cargo area cover is specific to these cars. It is also the same from 1982 to 1992 if I am not mistaken. However there are metal brackets that they mount to which are not present in cars that do not have them. The brackets would either have to be cut out of the donor car and welded in place or you'd have to fab some up and weld them in place. Additionally the interior sail panel plastics and plastic cover on the underside of the deck lid are different on cars equipped with the cover. Though it would be easy enough to cut out the needed holes in them should you try and do it.
Old Apr 13, 2010 | 06:07 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Would you like to buy another one?
Old Apr 13, 2010 | 10:40 PM
Car: 1992 RS
Engine: Carbed 350
There's no metal bracketry anywhere with mine. And has nothing to do with the sail panel at all. There are plastic holders that mount in the rear just behind the seats on each side, and there are two notches in the trunk lid. I have no idea what you are referring to here.
Old Apr 13, 2010 | 11:25 PM
87WS6's Avatar
I misspoke that. They are just behind the rear seats but there are brackets in there which the cover mounts screw into. I can take pics if need be, the interiors are out of both cars right now. Both my 1985 and my 1987 Trans Ams have this option.
Old Apr 14, 2010 | 11:04 AM
Car: 1992 RS
Engine: Carbed 350
Oh - - you mean under the plastic interior!
Old Apr 14, 2010 | 11:15 AM
87WS6's Avatar
Right.
Old Apr 14, 2010 | 11:25 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
I would I love the omni chargers
Old Apr 24, 2010 | 12:24 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
There's no such thing as an '84 IROC.
Old Apr 24, 2010 | 05:34 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
I'd like to know if they make new ones as well since most of the ones you find work like 30 year old window shades once you install them.
FYI: The bracket locations changed over the years as well in case it's a new install or if the interior plastic is ever swapped.
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
