Sparco seats in a 3rd gen.
Old Apr 12, 2010 | 07:35 PM
RoadHammer's Avatar
Car: 1991 Camaro Z28
Axle/Gears: stock
Hi,
I am interested in buying these seats from sparco:
http://www.sparcousa.com/pseats_street.asp?id=196
Has anyone tried to install any sparco seat in their 3rd gen? If so, pics would help.
Old Apr 12, 2010 | 07:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Sparco seats in a 3rd gen.
They would work fine. Could modify your stock rails to fit or run sparco rails if they provide them. I have corbeau forzas in my car and dimensionally they are about the same. Sparco is alittle taller and longer but should fit well since my forzas work great
Old Apr 12, 2010 | 08:40 PM
RoadHammer's Avatar
Axle/Gears: stock
Orr,
How do you like those Corbeau seats? Do you do much street driving with those seats? Are they comfortable on the street?
Old Apr 12, 2010 | 09:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I do alot of street driving on them and I love them. Never any long trips but wouldnt be a problem. They fit my frame size well, i'm 5'9" 170. They feel very tight on turns and i love to do alittle corner carving. I reused my power seat bracket so i can get the back incline abit more declined. It makes them abit more comfortable. They are fixed back 72 deg angle seats so they do sit up pretty straight but it is comfortable. If you get a reclining seat then you will be set for comfort.
Old Apr 13, 2010 | 12:56 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I put in some similar racing seats in my car and it gave me a bit of a headache, but not too much. Though, I was in a position to fabricate all new seat brackets, but I did it all without welding. Drill press, angle grinder, sheet metal (16ga or thicker steel is a must) and of course a can of rustoleum.
If you put a racing harness in, make sure you do it right and latch the rear belt 2 points to a roll cage. Or at least have someone put a harness bar in. Theoretically, it could be done by connecting the two rear seat belt brackets with a single bar, and just clamping them to that.
but all that stuff will be application specific.
Old Apr 13, 2010 | 12:58 PM
Car: 1989 Camaro RS
Engine: 305 TBI
Here's my Thread. some good Spine-saving information.
https://www.thirdgen.org/forums/inte...ng-racing.html
Old Apr 13, 2010 | 11:02 PM
RoadHammer's Avatar
Axle/Gears: stock
Thanks. I am prolly going to use the stock belts till I get my cage put in.
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
my86bird
Oct 23, 2015 12:20 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
