speedometer problem
Old Apr 21, 2010 | 02:57 PM
TMMYJMMY's Avatar
Car: 1989 IROC
Engine: 5.7
Transmission: AUTOMATIC
Axle/Gears: POSI
speedometer problem
i have an 89 iroc and i recently swapped a speedometer because the needle on my old one broke but once i put the new one in it's 5 off when i go about 10- 25 mph and once i get to about 40mph or higher it's off by 15 mph has anyone else have this problem or any solutions?
Old Apr 21, 2010 | 03:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedometer problem
If the speedo is reading low and/or bouncing, it's possible that in replacing the speedo head, you dislodged 20+ years of crude in the cable/housing and that that crud is causing problems. Check the following link for the cleaning procedure:
https://www.thirdgen.org/forums/inte...eedo-woes.html
If the speedo is reading high and/or bouncing, I'd guess the head is defective.
JamesC
Old Apr 21, 2010 | 05:33 PM
TMMYJMMY's Avatar
Car: 1989 IROC
Engine: 5.7
Axle/Gears: POSI
thanks i'll check and see if that does anything
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
