Whats easiest way to repair headliner?
So im thinking about replacing my headliner. Whats the cheapest and easiest way to replace it. how easy is it to remove? im thinking about removing it (i have ttops) then removing the old fabric and spraying some new adhesive and with the new fabric im gonna buy at jo anns fabric i will just put the new one in then wa la. do you think this be work out alright?
Car: 1989 Formula 350 / 2001 TA WS6
Engine: 350 / LS1
Transmission: Auto / Auto
Re: Whats easiest way to repair headliner?
mine was sagging real bad. the stock one is made of cardboard and deteriorates easily over 20 years. i know there is a post that details removing the foam backing without damaging the cardboard liner.
i took a look at the cost of the materials and my time. i decided to go with a abs liner.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I recovered mine for under $30 - this thread has a basic idea:
https://www.thirdgen.org/forums/inte...bric-rips.html
But, as stated, the cardboard is flimsy - I need to do it again, this time I'll try to paint some fiberglass resin on the backside with a brush to stiffen/strengthen it more - I've read this is a pretty successful tactic.
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
If you're going to recover, make SURE you get all the old foam off. Trying to glue new liner to old foam is like trying to glue your hand to sand.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i recommend the 3M spray adhesive. its expensive but works great.
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
