85 speedometer or cluster swap
Old May 12, 2010 | 08:09 AM
fsrracing87's Avatar
i have an 85 trans am with the 85mph speedometer. i got an electric 140mph cluster out of a car at the swap meet. will this all plug into play and should i put the whole cluster in or should i just put the speedometer into my original cluster?
Old May 12, 2010 | 08:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 85 speedometer or cluster swap
Welcome to TGO. Your 85 speedo, I believe, will be cable driven, so the swap would not be plug and play.
JamesC
Old May 13, 2010 | 10:01 PM
do you have any suggestions to make this swap work?
Old May 14, 2010 | 07:19 AM
JamesC's Avatar
IIRC, in later models with electric speedos, the ECM was involved along with a buffer box--as well as a tail-mounted VSS. You don't say if the old cluster is equipped with idiot lights, but if it is, that would further complicate a swap. You might consider a search. Perhaps someone has direct experience with such a swap.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
