Trunk Latch Help.
Old May 28, 2010 | 06:49 AM
LastKnownOne's Avatar
Car: 90 Camaro RS
Engine: 5.0 305 8cylinder
Axle/Gears: Stock Gears
Trunk Latch Help.
I have a 91 Camaro RS. When I first got it I could open and close the Hatchback no problem. One day I opened the trunk and tried to close it. The part that grabs the latch, to make the trunk stay closed, gets pushed down along with the latch instead of grabbing it. Is there a way to adjust that part to make it stay still or am I going to have to get new parts.
Old May 28, 2010 | 11:19 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Trunk Latch Help.
Sounds as if the clear plastic motor housing is broken. I only sell new ones that I reinforce with aluminum and epoxy. As a temporary bandaid fix I've seen baling wire, wood screws, chewing gum, duct tape, etc. used to hold the housing to the frame.
Lon
Old May 28, 2010 | 12:21 PM
Car: 90 Camaro RS
Lon
Motor housing? On a non-electric Trunk?
Old May 28, 2010 | 12:45 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Its not a non-electric trunk. It has a an electric pull down. You just barely click the hatch in place and the motor pulls it down. It was probably broke when you bought it and maybe had something placed (like mentioned above) to keep the latch from sliding in the rails.
Old May 28, 2010 | 11:41 PM
lonsal's Avatar
All Camaros and Firebirds came with a motorized pull-down unit from 1986-92. The exception being 1992 Convertibles which had their power pull-down unit swapped for a slam latch by ASC during the conversion. Regardless if it has the motor there now it had one stock from the factory. If it doesn't have a motor then someone jerry-rigged it. Depending on how they did it you may still need to replace the plastic part I mentioned.
Lon
Old Apr 15, 2012 | 08:34 AM
kemmie123's Avatar
how to make the electric trunk latch open when it is broke?
Old Apr 15, 2012 | 02:25 PM
lonsal's Avatar
To answer I'll need to know what style of pull-down unit you have. The 1986-early 91 (with a metal frame where it attaches to the car body) or the late 91-92 (with a tan colored molded plastic frame where it attaches to the car body).
Lon
Old Sep 8, 2012 | 03:57 PM
Shawn Jackson's Avatar
I have a question my motor broke on my lock I own an 88 iroc z and I want to get a whole new motor an the part the motor slides up and down. Is it possible without going to a junk yard?
Old Sep 8, 2012 | 04:34 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
You can buy rebuilt ones on ebay, or parts for the one you have. They go real fast at the junk yard. Good luck!
Old Sep 8, 2012 | 11:12 PM
lonsal's Avatar
https://www.thirdgen.org/tech/hatchpulldown.pdf
I've attached a link to the Tech Article here on TGO that I wrote on repairing your hatch pull-down unit. If just the clear plastic motor housing broke then you can replace just that. Or you can get a new-style replacement motor. I sell both a reinforced motor housing and a reinforced new-style motor. Look on my web site under Hatch repair items.
Lon
Old Sep 9, 2012 | 07:49 PM
I also have a question about a parking brake. I know my camaro don't have a parking brake like newer cars it only has a ebrake but I jus a new touch screen cd player deck for my car and in order for me to watch DVD on it I need to hook up the p brake wire up from the cd deck to my car but like I said it don't have one. Would it be possible to get a p brake switch from a newer car and hook it up in my car so that it always tells my cd play that my car is in park?
Old Sep 9, 2012 | 07:54 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Just out of curiousity, Is that just for a safety option so people don't go cruising down the road and watching movies at the same time or does it display on the screen that it is in park. I would install it myself on a +12v wire switchable when key is on and ignore what the book says..
Old Sep 9, 2012 | 07:58 PM
It says I have to put on the parking brake on the screen while I can still hear the music from the movie and it will not let me see the movie I can only see wat it says on the screen
Old Sep 9, 2012 | 10:34 PM
lonsal's Avatar
There is a ground wire that is switched on by pulling on the parking brake. The wire is under the center console and is tan/white. Most likely the audio/video system is looking for a switched ground and that is the one you'll use. Just tap into that wire.
Lon
Old Sep 10, 2012 | 03:59 PM
Alright man thanks also since ur so good with these cars I have one more question I want a lot Of power out of this car so I'm ganna order a Motown 427/ 650 hp but I have some ppl telling me I need to rebuild the original 305 to get the max power out of that. The only problem is if I get that 427 I would have to make it so I don't twist anything or break anything with that much power so wats ur opinion on it
Old Sep 24, 2012 | 05:09 PM
AZ91Z28's Avatar
Car: 1991 Z28 Convertible
Engine: 305 TPI- Stock
Transmission: Auto - Stock
MOTOWN SB CHEVY 427 / 650HP ALUM.HEAD-
ONLY $16,492.99
Part Number:
101021A
Brand:
World Products
SKU: WP101021A
Price: $16,492.99
MOTOWN SB CHEVY DRAG RAC E 427 / 650HP ALUM.HEAD-
why not get 2, they're small....
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
sylentnite
Sep 9, 2015 02:55 PM
