How To Replace Outer Door Handle
Old May 29, 2010 | 10:46 PM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
I'm looking to replace my outer door handles on my 90GTA. The manual says to remove a spring. What spring are they talking about? All I see is the rod that connects to the door handle and 2 bolts securing the handle to the door. Where is the spring???
Old May 29, 2010 | 11:19 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: How To Replace Outer Door Handle
The only spring I know of is the anti-rattle spring, which is part of the handle. When you remove the handle, you can see it on the under side, it's the piece that often breaks and causes the handle to rattle.
Old May 30, 2010 | 12:12 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Maybe they mean the metal clip for the door lock itself. I just unfasten the metal rod, undo the two securing nuts and out it comes. A flex head racheting wrench makes this a snap.
Old May 30, 2010 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I think Norcal is right. The clip, part #5, is spring-like as its shape applies pressure. I experienced a heck of time in removing it.
I believe that gorgeous finger belongs to me. I'm very photogenic .
JamesC
Old Sep 6, 2010 | 03:39 AM
gta90's Avatar
thanks for the replies. i didn't remove the spring b/c it made no sense to do so. the install went fine and the new handles work perfectly. one thing i did notice is that the plastic wire-rod insert piece was plugged in the wrong way. I had to pull it out and plug it in on the other side. I guess that's what I get for using a firebird manual while working on a GTA
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
