Lots of play in my steering column..help
Old Jun 11, 2010 | 07:51 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
alright...so my steering column is really loose...like it moves up and down alot and a little side to side...and this is without the lever being used...it is locked in place and its not getting stuck...idk what to do..
Mikey
Old Jun 11, 2010 | 10:00 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Lots of play in my steering column..help
This is a very common problem. You will need to remove the steering wh but eel, lock plate, and blinker assy to access the three torx screws that hold the tilt assembly together. Tighten these three screws and you will notice a huge improvement. It won't be 100% but it will be much better.
Old Jun 11, 2010 | 10:07 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
any instruction on this?? how to :P lol..
Mikey
Old Jun 12, 2010 | 02:39 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
https://www.thirdgen.org/forums/inte...eel-grant.html
Its got all the steps to take it apart
Old Jun 13, 2010 | 03:38 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
not sure if this will work on my t/a..gonna check now thanks
Mikey
Old Jun 13, 2010 | 04:24 PM
travis401's Avatar
Car: 91 Camaro RS
I thought the columns were the same between models? Just changed a little with the years?
Old Jun 14, 2010 | 04:14 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
mine is a GTA..has the radio controls and those bolts arent there....
Mikey
Azrael91966669
25
Jun 20, 2017 04:04 AM
deracer
Apr 11, 2016 12:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
SlowAZ28
Aug 31, 2015 07:56 PM
86White_T/A305
Aug 17, 2015 12:16 AM
