Turn signal lever help
Old Jun 14, 2010 | 02:13 PM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
So my pocket caught the lever as I was getting in the car. Snapped it right off and turned the wipers on. Does anyone have any ideas how to get the piece out thats stuck in there without taking the column apart. I got a new lever already. And it dosen't have cruise s no wires. I've been trying to use a pick set but it just isn't working. Any ideas?
Old Jun 14, 2010 | 02:15 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Turn signal lever help
I believe you will have to take the steering wheel off and go from there... there most likely is a bolt inside that is holding the lever in place...
Old Jun 14, 2010 | 03:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/post...980-post4.html
JamesC
Old Jun 15, 2010 | 11:51 AM
DAVEY420's Avatar
Car: 85 IROC Z
Yeah I'm hoping to not have to take it apart but if I do oh well. Theres like 1 inch stuck in there and I just can't push that tab down to get it out.
Old Jul 7, 2010 | 09:20 AM
ms87iroc's Avatar
Car: white 87 iroc-z
Engine: 5.7 tpi
Axle/Gears: 3:27
I also need to install new turn signal, cruise control lever. I read your instructions and seen diagram. Does it just pull out? I tried pulling it out but maybe didnt pull hard enough, in fear of beaking it off in there. I thought maybe there was a screw holding it in, and i had to take the column apart. help
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
