Fuel Pump question help
Old Jun 23, 2010 | 04:08 PM
tylerf's Avatar
not sure where i should had posted this but here it goes, im changing out my fuel pump and i decided to just cut a hole in the truck to access it. my question is how do i go about cutting the fuel lines so i can pull out the pump, just use a hand saw? or metal cutters, i plan on cutting them and putting hoses to re attach them
Old Jun 23, 2010 | 04:19 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Fuel Pump question help
no clue on your experience with tools but i use hand saw or saw zall.
Old Jun 23, 2010 | 04:37 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Use the search feature in the fabrication section. Tons of first hand experiences outlined there
Old Jun 23, 2010 | 05:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Use a pipe cutter - they are $10, and won't create as much heat and potential sparks as a saw.
Old Jun 23, 2010 | 07:21 PM
Car: 90 formula
Transmission: auto
Old Jun 23, 2010 | 08:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
mini pipe cutter.
i dont condone this way of swapping the pump, but if you have to do it this way, cut a clean hole and make a nice sealed cover plate to cover the hole. dont hack it up.
if the car is TPI/MPFI, you really shouldnt use rubberhose and hoseclamps on the feed line, it should be flared to do it right.
here, use this for a template
avoid power tools, since they are not very delicate and make sparks, which can cause a fire/explosion. If you cut the hole with tin snips, cut slow and dont completely close the cutters every snip. you will get a cleaner cut that way.
Old Jun 23, 2010 | 08:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if the job starts to look like this, you are doing it WRONG
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
