Cable driven speedo to electrical
Old Jun 27, 2010 | 10:33 AM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I have a 86 Pontiac Firebird that had an original cable driven speedometer and a couple weeks ago I swapped in an electrical one and have no idea how to get the speedometer to work now. I heard that I have to run a computer from the transmission to the speedometor but is there an easier way.
Old Jun 27, 2010 | 11:13 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Cable driven speedo to electrical
You can use a universal interface box like the one from Dakota Digital.
http://www.dakotadigital.com/index.c...rod/prd126.htm
Old Jun 27, 2010 | 01:54 PM
MikeSammy's Avatar
How do i go about hookling the box up. Do i hook the box up to the transmission then run a harness to the guages
Old Jun 27, 2010 | 08:06 PM
Al Hasse's Avatar
They also have a sender you can use, you can step it down from the 8K pulse per mile it puts out to the 2K or 4K your car requires using the SGI-5 box linked above.
Their sender is here
http://www.dakotadigital.com/index.c...rod/prd109.htm
Old Jun 27, 2010 | 09:00 PM
MikeSammy's Avatar
SEN-01-1 - 8K pulse generator with adaptor cable for GM transmissions with cable drive speed output
Would this be the only item needed. If so, do i insert the cable and attack the wires into the wiring harness for my car?
Old Jul 4, 2010 | 09:18 AM
69-er's Avatar
Where did you get the speedometer? I've always wanted to do that for my 83 Camaro. Do they make a bolt-in mechanism? I figured I could swap the face to keep it looking stock.
Old Jul 5, 2010 | 03:04 PM
MikeSammy's Avatar
I found the speedometer in a junk yark and took a hammer and broke the old one out. I too kept the dash bezel to make it look factory!
Old Jul 5, 2010 | 04:06 PM
69-er's Avatar
What car did it come out of?
Old Jul 5, 2010 | 05:54 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Camaros had cable driven speedometers from 82-89.
Firebird had them from 82-85, I believe.
You wont find one that will fit right into your camaro and look year-specific. The dash design changed in 90.
Old Jul 5, 2010 | 06:34 PM
69-er's Avatar
I figured when they changed the inst panel that's when they went to the electronic speedo.
I'm hoping there is another make/model out there that has the same sweep angle and where I could possibly use that mechanism with my face.
Old Jul 8, 2010 | 12:03 AM
gilly327's Avatar
Car: 86 firebird se/91 camaro rs
Axle/Gears: 3:73/3:42 4th gen
i was wondering which years had cable,thanks.my 86 firebird is electric speedo and i want cable.
Old Jul 8, 2010 | 09:11 AM
MikeSammy's Avatar
My 86 firebird had a factory cable driven speedo but why do you want one. The electrical is more effiecent
Old Jul 8, 2010 | 06:43 PM
69-er's Avatar
Now I'm confused! Which kind of speedo should an 86 have?
Anybody know when the Firebirds started using electric? If I could find a pic of an electric speedo, I might be able to see if the guts could be retrofitted to my 83.
Old Jul 8, 2010 | 08:09 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
86 Firebirds had option for Elec and Mech speedos, probably based on the tires and cluster that you got.
all 140MPH clusters are electronic.
Old Jul 8, 2010 | 09:40 PM
69-er's Avatar
That's interesting! Is that the first year electric's were available?
Anybody have a picture of one?
Old Jul 8, 2010 | 10:41 PM
Zepher's Avatar
Ya, first year electric was available,
here is my 86 Trans Am with stock 140MPH Electric Cluster,
Old Jul 9, 2010 | 08:47 AM
69-er's Avatar
The sweep looks the same but it's clocked wrong. Maybe I can turn the needle and get it to turn CW about 45 degrees. Time to hunt on eBay!
Thanks Zepher!
Old Jul 9, 2010 | 09:19 AM
Zepher's Avatar
what is cool is the cluster I got from my 1990 Formula that I put into my 88 Formula,
Take a good look and tell me what is different,
Old Jul 9, 2010 | 09:40 AM
MikeSammy's Avatar
Oh I see the difference! The factory 85 had the km/h but the 1990 cluster doesn't. I have that same guague cluster that you have in the 86. The only problem is that I have to go from cable to electric to run it.
Old Jul 9, 2010 | 11:01 AM
Zepher's Avatar
I had never seen a MPH only cluster before in a 3rd gen. I didn't even realize it was MPH only for a couple of weeks. I was driving and was thinking that the speedo looked a little strange then realized it was missing the KPH scale.
In the History board they mentioned that it might have been an 86 Cluster.
Old Jul 10, 2010 | 06:37 PM
gilly327's Avatar
i want cable driven cause i figured it would be cheaper and easier to get a speedo,cable,and transmission guts then to buy whats needed to install the electric speedo i have.
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
topteam54
Oct 6, 2015 12:21 AM
89newfun
Sep 16, 2015 09:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
