window motor
Old Jul 8, 2010 | 03:10 PM
camedout camaro's Avatar
window motor
what is the best way to replace the window motor in a 92 maro . is it pop rivits or bolts? thanks for the help.
Old Jul 8, 2010 | 04:11 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: window motor
You'll have to drill out the factory rivets. Best way to install new is to use new rivets. The replacement motor should, however, come with new bolts you can use. If you use the bolts you may want to use a little JB Weld to hold the nuts in place on the motor assembly so you can start the threads of the bolts. It's virtually impossible to finagle those nuts back there by hand. Just don't get the JB on the threads and use some locktite to keep the bolts from coming loose over time.
Old Jul 8, 2010 | 10:08 PM
tekkitan's Avatar
Car: 87 IROC-Z
Re: window motor
I believe there is a nice technical article on this site for replacing the motors as well.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
